07-31-2008, 12:34 PM
#151 (permalink)
Ecomodding Dabbler
The chant of the ecomodder: mold and sell!
Shouldn't that be 'chant of the ecomolder'?
08-02-2008, 07:27 PM
#152 (permalink)
You can count me as one ready to buy. Paypal and ground shipping to California should make it a cheap and easy transaction. It looks freakin' cool so far!
Mold and sell!
08-02-2008, 07:34 PM
#153 (permalink)
Well, I'm telling anyone who will listen: the easiest way to do this is a sheet of plastic (ABS?). Since there aren't really any compound curves in this shape, that's the most sensible approach. I'll happily make a pattern people can use to quickly make the same thing I'm spending too much time on...
Working away, sanding, fairing, sanding, fairing...
08-03-2008, 09:30 PM
#154 (permalink)
Spent several hours working on the Kammback today. The sides & tops are smooth, and the finishing work on the trailing edge should be done tomorrow. Remaining: the finishing work on the forward edge, and paint.
I'd take some pics, but the thing still pretty much looks like it did in the last photos I posted.
08-03-2008, 09:42 PM
#155 (permalink)
Addicted
Cool I am happy you are still making progress, can't wait to see it under some paint. I believe it is actually going to look like it came that way, all your mods look so factory.
08-04-2008, 08:57 PM
#156 (permalink)
Holy moly! No pressure. Let me diffuse some of the expectations: it's not going to be perfect!
Spent some time working on the leading edges this evening. Got them nicely trimmed and started on the finishing work.
I did make one fairly big mistake overall: When I initially trimmed the edges, it opened up the cardboard sandwich to the elements. With the amount of rain we've had, the cardboard has wicked in some moisture. The result is a couple of spots are noticeably softer. The corrugation has gone mushy.
Not that this thing was ever going to be terribly strong - it would not survive a goat walking on it.
People: just use a piece of ABS when you make yours!
08-06-2008, 08:10 AM
#157 (permalink)
Originally Posted by groar
Have you ever tuff tested your rear wheel skirts or your front grill block ?
Yes, though it was one of my first tests, so it's not as rigorous as some of the later ones (not a proper A-B-A comparison).
See: Testing grille blocking & wheel skirts: +5.7% improvement - MetroMPG.com
08-06-2008, 05:14 PM
#158 (permalink)
Addicted
No pressure from me just saying I like your mods look clean.
ABS sounds easier/cheaper but fiberglass painted would look a lot better. I am glad you went fiberglass direction, helps me get over my fear of it.
Thanks for posting this would not have known otherwise about doing something like this.
08-06-2008, 07:54 PM
#159 (permalink)
I see I'm proving my "SLOW" user title. It's been over a month since I started on this! Crud.
Anyway, first primer coat tomorrow. Yay, milestones.
08-06-2008, 08:27 PM
#160 (permalink)
pics?!?! I only open this thread to look for photoz, haven't actually read any of it
