08-18-2013, 06:47 PM
#12 (permalink)
A$5,000 for a used CBR250R. They are $3,300 in the USA. I see the US dollar has crashed in Australia. They are nearly the same.
08-18-2013, 06:49 PM
#13 (permalink)
The initial purchase price for almost everything is higher here, sometimes double. Our wages are good but the prices are higher too.
09-05-2013, 06:29 PM
#14 (permalink)
mpg
Originally Posted by PeterS
I've been looking at a variety of bikes from the perspective of building an aero tourer and it seems that there is a significant advantage in fuel injection. The trouble is that here in Australia the only fuel injected bikes are quite big, usually 750 cc and up (especially at a price I can afford).
I could go to a smaller carbed bike but a question first about horsepower potential and used horse power.
With a cd of 1.0 a K75 BMW gets 43 mpg US at 70 mph as the spec sheets say. But using the calculator at the top of this page if I feed in a cd of .4 (as in a full Vetter fairing ) it says I will get 99 mpg US.
Is this believable?
Firstly this is a large engine , a 3 cylinder 750 but also a very good one that has an early fuel injection system. If the reduced drag only requires 8 hp versus 17.5 hp with a cd of 1( per the calculator ) is that all the engine will develop ? Meaning only using that much fuel .
Any input is welcome !
General Motors published a relationship between drag reduction and mpg which is valid if BSFC can be maintained.
A 10% drag reduction will net a 6% mpg improvement at 70 mph.
Going from Cd 1.0,to Cd 0.4 is a 60% drag reduction and should produce a 36% mpg increase.
1.36 X 43 = 58.48 mpg if all other factors are held constant.
If the frontal area were to be reduced as well as the Cd,you could expect better numbers.
NOTE: it is essential to do gear-matching after the streamlining such as to maintain the same engine loading as existed before the streamlining or you risk losing up to 60% of the benefit.
09-05-2013, 06:35 PM
#15 (permalink)
Gear matching is a problem on a BMW, a chain drive makes things a lot simpler.
09-05-2013, 06:53 PM
#16 (permalink)
gears
Yes,the shaft-drive makes for an interesting challenge.I've got a Honda 700 Shadow and face same challenge.
09-05-2013, 09:46 PM
#17 (permalink)
I believe they refer to Hawaii's "Paradise tax" or something.
09-05-2013, 11:05 PM
#18 (permalink)
I have BMW too, but not with shaft - with a belt, and the gears are still factory default after 5 years.
But I still get decent numbers Not as good as sendler does with his CBR250.
It would be nice to try a different ratio, honed to our 56 mph speed limit - but the easiest way would be scrap the whole final drive and go to chains. (Something I'm still reluctant to do )
The Following User Says Thank You to alvaro84 For This Useful Post:
09-06-2013, 12:46 AM
#19 (permalink)
My next bike will be a BMW G650 cross country , it should be good for 67mpg US in stock form.
09-06-2013, 09:41 AM
#20 (permalink)
How do you do gear-matching?
