10-01-2018, 01:40 PM
#11 (permalink)
The popup tent camper people have a 4 post lid lift system that operates off a single crank which so could be electric. We were going to make hard folding sides for bear country and cold weather camping before we bought the casita. I don't do stairs or ladders at 2 am potty runs anymore, falling down with full bladder is highly annoying.
10-01-2018, 06:55 PM
#12 (permalink)
This will have to do:*
Differing curves in the forward and aft sections might need to be reconciled. No headroom problems if you don't want them.
_______
Part of that dream as I understand it is retiring and traveling the country (USA only) in an RV.
I bought into the dream but I couldn't afford to even take it on the road.
*Back to doing graphics by hanging a transparency over the monitor, just like the 19080s, before I got a Thunderscanner.
10-01-2018, 08:23 PM
#13 (permalink)
Differing curves in the forward and aft sections might need to be reconciled. No headroom problems if you don't want them....
One could just start with a taller front cabin and then taper down, but the end result would still be a larger hole in the air compared to a collapsible version.
I did not see any tall caps on just the front end cabs, but one could always create their own. I mean if you have the skill to make a huge top, why not a mini top for the cab?
Perhaps they could be one in the same.
EDIT:
Scheme-3
Added a non-moving shell, simple as can be. Bed at short tail end, forces the toilet/shower location to middle or front for headroom. No back door on this one.
I like it, what is it?
Corvair based?
10-01-2018, 09:28 PM
#14 (permalink)
All that work and no Thanks?
Why not start with a top chop?
It was a 1964 Clark Cortez. I held it 10 years and never got ahead of the maintenance.
10-02-2018, 12:23 AM
#15 (permalink)
Start with the extended van, and build a profile cap to mount on the chopped cargo box. Hinge it so you can flip the cap up. You already have 76 inches of height at the hinge.
10-02-2018, 10:22 AM
#17 (permalink)
Delayed thank you, your comments led to the creation of Scheme-3 FYI.
To clarify, the roof on your overlay scheme is intended to be a two-piece clam-shell that gets lifted up, right?
That works for me as I'm short and my wife is even shorter, we may not need to raise the roof cap mechanically at all with those dimensions. Again this is a " just a for fun" study, a musing of daydreams. Nice work, thank you for putting that together for us all.
Originally Posted by airbiteses
Hello, in Europe there are several models Fiat ducato camping, max cemping, 4x4 etc. eg:
Fiat Ducato 4x4:
Nice links, thanks.
It's like designs that initially appear to address aerodynamic concerns end up failing or surrendering to some mundane practicality of function.
What this tells me is that aerodynamic design is still a fashion statement hired out to some stylist for marketing concerns and fails to get faithfully executed due to poor hand offs and delegation to others that do not embrace the concept and just want to retire early themselves.
10-02-2018, 11:47 AM
#18 (permalink)
While I agree with your statement, also remember it doesn't have to sacrifice much to be quite aerodynamic, nor does it have to "look" aerodynamic.
Best example of this is the Vixen motorhome. It had an actual Cd around .30. But, to most folks, it is still a box.
And boy do I wish Navistar published a Cd for the Monaco Vesta / Holiday Rambler Trip. I bet it was similar. And again, very few folks would ever really think it's much more than a big box.
Both these examples follow the simple method of rounding the front corners until the aero doesn't get any better, than taper the rear as much as you can. Didn't take much taper (which is loss of interior space) to get pretty good.
That said, if you don't consider low .30 as good (you didn't really say), getting it lower would indeed require more sacrifice. Being that my own motorhome is probably over .5 (data suggests it's almost .6), I'd take .3 any day.
(Images attached to save anyone who isn't familiar with these the search time.)
10-02-2018, 12:31 PM
#19 (permalink)
Best example of this is the Vixen motorhome. It had an actual Cd around .30. But, to most folks, it is still a box. ..............
Thanks for posting the Cd, did you reference a source or just go off memory?
The roof taper is appearing on many vehicles today without much fanfare or acknowledgement to aerodynamics, this somewhat stealth introductory of aerodynamic design will eventually mark flat roofs as antiquated I suspect.
We are not seeing a lot of tapering in plan outside of hatchback and crossover greenhouses, and you really have to look for it. The smaller Volvo's and the Juke come to mind.
The Vixen and other larger RV's benefit from a longer length ratio to lower their Cd as much as anything else going on.
However, what we are studying here and I suspect will be seeing more of in the future is taller height to length ratios that will have to resort to tapered roof profiles to maintain any kind of fuel efficiency.
The hinged and telescoping roof schemes are an attempt to skirt around the height issue and get a more friendly length ratio.
10-02-2018, 02:47 PM
#20 (permalink)
There's sources quoting "<.30". But as I recall, Bill Collins did extensive testing in a wind tunnel (U of M in Ann Arbor?) and later sent a full size vehicle for testing (at the Bendix Proving Grounds) which came in a bit higher than the model (as happens). Somewhere online is a complete history written by Bob, which he presented at an owners convention or something like that. I'll google that a bit more...
Also recall that the Vixen had a pop up roof, later replaced with a fixed, higher, roof, but that version wasn't aero tested.
So long as the front contours result in laminar flow along the top and sides, the length isn't as important. I bet a Vixen could be shortened quite a bit before the aero got worse. I think long bodies benefit from the air getting reattached along the length of the body. If it never detaches, it could be shorter.
