Old 01-09-2015, 01:05 AM   #21 (permalink)
90 day: 31.19 mpg (US)
Obviously you need a pink implosion wing!
I would drive the dog van from Dumb and Dumber if it doubled my mileage, but when I told my "mother-in-law" that I broke 50 MPG on my previous tank she just shrugged it off.
Old 01-09-2015, 07:40 AM   #22 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
Mutt Cutts!
I find it easier to tell people how much money I saved as most people can relate to money in their pocket compared to MPG. Fer example, I've saved between $500 to $700 in fuel costs every year (6 years) since I started aero modding my T-100...which has paid fer the purchase of my truck and ALL mods to date. My long road trips calculated out to $0.09 per mile.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (01-09-2015)
Old 01-09-2015, 09:41 AM   #23 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
A quick note to InnovativeWindTunnelGuy:
If you're an actual wind tunnel guy, I think you'll appreciate that we prefer testing and documented results over rhetoric and anecdotes.
The "inventor" claims double and even triple the usual fuel mileage for vehicles using his device, and that it works better at higher speeds. If you spend much time here you'll see that that flies in the face of our usual philosophies. Doubling one's usual fuel mileage is the holy grail, tripling is the essence of the Unicorn Hunt. To date I can only imagine one guy could claim having done that: Diesel Dave in the White Whale, and his posted average speeds are the epitome of "modest."
The "inventor" uses a lot of gobblydegook to talk about his creation. Many of the terms make no sense whatsoever, even if you assume they are sort-of contextually appropriate. For further exploration of this concept see:
But don't let us dissuade you. We're all about testing, here. Test, document, test again. Test with and test without. Eliminate as many other variables as humanly possible.
And then tell us what you've learned. It would be quite something to discover if there were an actual unicorn, and that it was useful.
The Following User Says Thank You to elhigh For This Useful Post:
Old 01-10-2015, 02:25 PM   #24 (permalink)
implosion
http://3.bp.blogspot.com/--O2vbpP28U...99111_orig.jpg
freebeard (01-10-2015)
Old 01-10-2015, 02:46 PM   #25 (permalink)
Ha Ha- The ORIGINAL ricer speed holes!
Old 01-12-2015, 04:09 PM   #26 (permalink)
Aerohead, I am embeding your image to view it!
The Following 3 Users Say Thank You to Xist For This Useful Post:
aerohead (01-13-2015), Cd (01-13-2015), ChazInMT (01-12-2015)
Old 01-12-2015, 04:11 PM   #27 (permalink)
Wouldn't that create excess wind noise? If it makes wind noise, wouldn't it be creating drag?
Old 01-13-2015, 04:31 AM   #28 (permalink)
A brick wall with a hole in it will make more wind noise than a flat brick wall, but it will still have less drag.
Old 01-13-2015, 01:59 PM   #29 (permalink)
Not necessarily.... Depends on the hole!
-soD
Old 01-13-2015, 05:39 PM   #30 (permalink)
wouldn't that
This car would have the aerodynamic dignity of a Grumman Avenger dive brake.
A true sky-ripper! Waring blender.'Bass-O-Matic.'"Holy Parachutes Batman!"
After the 1/4-mile run,they probably took their hole saw out to the desert and used it for target practice.
Smokey Yunick acid-dipped his cars for weight reduction,maintaining their aerodynamics (of which he cheated on).
