Old 01-28-2019, 06:22 AM   #21 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
That's a pretty good idea, as far as better than band-aid solutions go.
The Following User Says Thank You to Stubby79 For This Useful Post:
California98Civic (01-30-2019)
Old 01-30-2019, 09:35 AM   #22 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
It has been all bolted up for a couple days now. Running well. Starts well. No sounds of grinding or anything else undesirable. And I couldn't even fit that both over the stud. Unfortunately when I stepped up the size of the stud to fill the hole for the bolts better for stability when the motor is cranking I neglected to consider whether I be able to get a ratchet head on to the nut to tighten it down. Anyone know especially narrow short nuts that can fit over a 7/16 in stud with fine threads? I don't know I don't know if it matters that much since it's working fine and I only intend to hang on to it for a few months this way before pulling the engine and drilling out the broken parts, but it's an interesting detail to try and resolve and I might learn something.
Old 01-30-2019, 12:15 PM   #23 (permalink)
Fine thread might mean using an aircraft jam nut which is 1/2 high, or make your own with a hacksaw. Install uncut side towards load.
Old 01-30-2019, 02:03 PM   #24 (permalink)
Cyborg ECU
Something like this?
Item # NAS509-5, Drilled Jam Nut On Wicks Aircraft Supply
Old 02-05-2019, 10:54 AM   #25 (permalink)
That is the critter. Not full load bearing but 5000 lbs in shear might be enough
