Old 04-17-2021, 01:12 AM   #31 (permalink)
90 day: 35.79 mpg (US)
I kind of wish that I had seen this before I bought a tablesaw, but you are supposed to use a tablesaw to build it, and I am supposed to get a stand before I use the one I just bought:
Old 04-17-2021, 01:59 AM   #32 (permalink)
Were I to drop coin on something, it would probably be the Maslow CNC. https://www.maslowcnc.com/
The jointer is for facing lumber.
Old 04-17-2021, 10:55 AM   #33 (permalink)
Or not having to rip to a thinner profile or make tapers or precision angles. I do like the DIY planer, but it looks useless for more than 2x4
Old 05-07-2021, 12:16 AM   #34 (permalink)
I clamped a straight 2x6 to the tablesaw fence and trimmed the curved part of the inside edge, but it didn't seem like an 8' board was long enough, so I flipped it over, trimmed the offensive part of the other side, flipped it back, and straightened out that first side again.
It fit!
Mom claimed that it was an inch narrower than the other boards, but I measured it, and the difference was a whopping 1/16".
She was only off by a factor of 16!
Since everyone knows a layer of paint is 4 mil I put on one layer of primer and 7 of paint. Now it looks like it has been there 30 years and has been painted multiple times!
I haven't measured it again. I am not going to. Mom can do push-ups.
I don't know what happened. I needed to carefully line up the top board and put a screw into the bottom left. The top is off-center by 1/4" and there is an 1/8" gap between the window and the top board, but I don't think it looks bad from... space.
I sanded down the high spots after 4 total coats, but not after I finished. There were some runs on the ends, but I don't think that created the gap, I needed to mess with the top board because there was originally a gap in one corner.
I need to cut, prime, and paint 3 more boards. I don't know if I already planed them. If I use the tablesaw instead of the planer, they will actually be flat, right?
Mom keeps ordering me to work on other projects--or drop what I am doing for dinner (I don't--there isn't enough daylight!). My sister keeps saying that she will bring Mom a larger freezer and haul off the current one. She announced that she was coming today, so I kept making time to organize the garage yet again.
Mom insists that she cannot close the freezer, not because she buys food faster than she uses it, or because my brother never tries to organize the food he puts there, he just throws it in, but because of all of my food.
I may have two bags of peas in there. Here is the crazy thing: If I had food in there I would eat it!
Of course, Mom claims that her garage is a mess, not because she refuses to clean it out, even when I finally managed to convince her to promise to, or because she has an entire carload of Christmas decorations, but because of all of my car parts.
My dash? Am I supposed to fix that car or work on all of her projects?!
My sister bailed, though, which means that we won't have anyone here in the immediate future with the capacity to transport a freezer--or unwanted mattresses wasting space in the garage.
It also means that I needed to put everything back, and now I will need to create a path if or when she finally visits.
ID:	30611   Click image for larger version
Old 05-07-2021, 10:42 AM   #35 (permalink)
Gaps and holes are what caulking are used for, also known as 1/2" paint.
Dunno, my wife can see 1/8" out of plumb over 8 ft and unless I break out my 6ft mason level, I can't measure it. Thank god I don't have a transit.
Old 05-07-2021, 11:00 AM   #36 (permalink)
When I tried to look up what caulk could withstand subfreezing temperatures I got a headache, but I guess I need to figure it out!
Old 05-07-2021, 02:45 PM   #37 (permalink)
Polyurethane Caulk
Donald J Trump 8/21/21
Disclaimer...
But...
I play one on the internet.
Old 05-07-2021, 03:41 PM   #38 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Looks good.
When you caulk leave the bottom of the bottom trim piece uncaulked. You need to give any water that sneaks in under the trim a place to drain out.
The Following User Says Thank You to JSH For This Useful Post:
Xist (05-07-2021)
Old 05-07-2021, 04:12 PM   #39 (permalink)
Melt down HDPE plastic bottles at 375 degrees F, until it is the consistency of [hot] bubble gum. Use a brayer [roller] and two strips the right thickness and roll out a slab. slice it to shape. let it cool, and hammer it into the slot.
It will outlast the rest of the house.
Old 05-08-2021, 10:22 AM   #40 (permalink)
Ummm hot bubble gum? Which brand exhibits this characteristic un wetted by assorted liquid?
Obviously my bottle melt skills are insufficient.....
Any caulk manufactured in the last 50 years is freeze proof when cured/dried/solvent reduced. Continue to seal? That is a hard question.
