06-12-2013, 09:35 PM
#471 (permalink)
Take the "s" out of https://... in the YouTube link and it will format properly. Not sure why the code is derailed by just one letter, but it is.
06-12-2013, 10:26 PM
#472 (permalink)
NightKnight
My post (with the video) is fine, but post #286 is still ... messed up.
06-13-2013, 06:54 AM
#473 (permalink)
Fixed #286.
06-14-2013, 03:21 AM
#474 (permalink)
I have a problem with BB coded tables in post #198 it seems that something is wrong there. I've even deleted my message and posted it again with the clear text/code - the same outcome. Could you please check that? Maybe I'm doing something wrong there?
Thanks in advance
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
06-14-2013, 07:43 PM
#475 (permalink)
Hydrogen > EV
Throughout the forum, on the side bar that shows the cars in ones garage, the 2012 models react differently. For example, the 2008 Escape shows as Name- '08, while the 2012 shows as Name- '012.
Clearly, lol, this is not a big issue! But I thought I should mention it.
06-19-2013, 04:55 PM
#476 (permalink)
Vehicle year "bug" fixed (where year > 2009). I also added "Make" to the vehicle descriptions, since I was starting to see some model names I didn't know!
What's the issue? There is a bug in BB coded tables that adds whitespace to the post outside of the table. Is that it?
vBulletin 4.x actually has a really nice table feature built in the post editor (user selectable). For an example, see post #1 in this thread: Mirage economy run Thailand: 31.9 km/L (3.1L/100km, 75 mpg US) 5-spd
One of these days we're going to have to upgrade EcoModder to 4.x when they eventually announce end of support for 3.x. I'm putting it off because they changed so much in vB4 that it's not 100% compatible with custom code written for this version (like the fuel logs, garage, etc.). It will all need to be updated.
06-20-2013, 02:53 AM
#477 (permalink)
Yes, exactly that
Thanks for the info, I was thinking that I'm doing something wrong because t-vago posted a nice table without such white spaces. t-vago's table
06-20-2013, 10:17 AM
#478 (permalink)
NightKnight
I thought there was a way to do HTML code to create a table...
06-20-2013, 10:25 AM
#479 (permalink)
HTML code is not active - for me at least
06-20-2013, 10:28 AM
#480 (permalink)
t-vago found a workaround to the line return bug in the way he formatted his table BBcode. By putting each line break immediately after the cell data, rather than after the closing cell & row tags, the whitespace problem doesn't happen.
I applied that code formatting approach to your first table in post #198 and it removed the extra whitespace above that table. (That formatting makes the table harder to read in code view though.)
