06-23-2020, 07:51 PM
Restore Engine Restorer
Anybody on here ever use Restore engine restore and see good results? Until here recently I've never really been a high mileage guy besides the $700 civic which I promptly sold when they alternator kept going out. Now that the Prius is up to 165k and is a 2010 consuming 2qts of oil every 10k miles I think it might be interesting to see if it does work.
( https://www.amazon.com/Restore-00009.../dp/B00HJVEWVG)
I'm know I can always just add oil forever but I'm interested to see the effects on the next oil change and would like to keep the pcv and egr cleaner to keep the idle problems away. Planning to keep this Prius until it blows up and it seems like the engine blow by is probably the worst part of the car.
Now I wanna preface this by saying I don't believe in any additives besides this one...possibly. Hit me up with your experiences below!
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
06-23-2020, 08:34 PM
I’ve used it before and it actually brought compression up some on the engine in question. Not by a massive amount but it helped nonetheless
My current Ecotec project...
My last Ecotec project...
06-23-2020, 09:17 PM
A quart of oil every 5K miles is nothing to worry about, a lot of new engines burn more than that. I say try it if you want to though, what's the worst that could happen? A lot of people including myself have used it with good results and I have never heard of any problems from using it. I would suggest adding it to relatively clean oil though, so if you are about due for an oil change I would wait until then to add it.
I don't know much about these Prius engines, but bad valve stem seals often cause oil consumption issues and from my experience go bad more than piston rings. The rubber gets hard and cracks with age and no longer seals effectively, allowing oil to get past. The good news is that on a lot of engines replacing the valve stem seals isn't a big deal and can easily be a DIY job depending on the tools you have and your mechanical skills.
06-23-2020, 11:51 PM
True. Technically if this was an american car this oil consumption amount would be pretty normal. I'll have to take some time out of the day and compression test the Prius.
06-24-2020, 10:00 AM
Cyborg ECU
Great minds have similar YouTube profiles... I posted this same thing a few days ago:
https://ecomodder.com/forum/showthre...tml#post626518
My take would be concerns about gaskets. What effect will it have on the gaskets that the oil come in contact with. Stop Leak seemed to alter the texture and quality of all the gaskets. They're fine, but they're gummier in some cases. Looks weird.
06-24-2020, 11:44 AM
Moderator
It's a known piston ring issue on the 3rd gen Prius. Toyota issued a TSB a few years ago; the fix is replacement of the pistons and rings to the updated MY 2015 version. But it only applies once consumption reaches 1 quart/1,300 miles for vehicles in-warranty.
The Following User Says Thank You to Vman455 For This Useful Post:
06-24-2020, 12:03 PM
Originally Posted by Vman455
I didn't realize that, good to know.
06-24-2020, 04:45 PM
Moderator
I wish I'd known it before I bought a Prius! But mine isn't consuming any oil yet at 90,000 miles. If it starts I'll probably throw in a can of this stuff just to see if it does anything.
06-24-2020, 05:52 PM
#9 (permalink)
If you want to prevent piston ring problems, use a high quality synthetic oil and change it regularly. I wouldn't go over 5K miles, especially since these engines have a known problem with the rings. Oil is cheap compared to rebuilding the engine.
06-24-2020, 07:04 PM
#10 (permalink)
Cyborg ECU
I wonder if there would be any use in throwing in a can pre-emptively? In other words, is it the kind of issue where catching it earlier can prevent the problem from becoming significant? Could pre-emptive use somehow protect the rings from wear?
