Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-13-2010, 03:09 AM   #41 (permalink)
some Yammie bits... note the dual-tract intake, where each cyl breathes through one tube at low rpms and both when wound out... pretty much wasted tech for me
Old 05-13-2010, 08:31 PM   #42 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
That's absolutely insane there, having dual runners on the intake. But I suppose allowing only 1 intake valve to suck in the air at low rpms would increase the airflow speed and make the gas vaporize that much better.
I bet it sounds like a beast when it takes off at WOT. Not that you would know about that
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 05-13-2010, 08:33 PM   #43 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
No, it really doesn't. They're great engines, but they sound like poop. (Comparatively)
Old 05-14-2010, 03:40 PM   #44 (permalink)
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
Intake runner length, and diameter make huge differences in where a motor makes it's power.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
Old 11-13-2018, 03:06 AM   #45 (permalink)
Xcelplus
Dupont v's Slick-50?
Hi,
Both Dupont and Petrolon agree with you. They both state that Teflon is not the active ingredient in Slick 50 (the original pre 1983 formula).
Originally Posted by Christ View Post
I couldn't help but notice that you (OP) say you found gains from using Teflon additives in your oil.
Maybe this is the time to point out that DuPont (the maker of Teflon) specifically maintains no knowledge of any advantages from using their product in motor vehicle engines.
Old 11-16-2018, 04:46 PM   #46 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by curiosity View Post
Hi,
Do you realise that Dupont ended up buying Slick-50?
There have been a variety of products marketed by various companies under the brand label "Slick 50." Currently, the only one on the market is owned by ITW Global Brands, which has a stable of automotive products including Gumout and RainX. Previously, Slick 50 was owned and marketed by Shell, which acquired it when it bought Quaker State, which was fined by the FTC in 1997 for making false and misleading claims about the product. A company called Xcelplus (which appears to be defunct) tried to bring their own Slick 50 to market in 2004, claiming it was the original formula and that the Shell brand was a copy. As far as I can find, Dupont does not now and never had ownership of the Slick 50 brand.
Also, the post you responded to is 8 years old....
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
curiosity (02-24-2022)
Old 11-20-2018, 12:15 AM   #47 (permalink)
Xcelplus
The real point is that it was only the Slick-50 name that was sold in 1983 (not the formula). Who better to explain what happened than the guy who invented it?
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 01:06 AM
Moly Gear Oil Additive Sources? Redline MTL or ??? rmay635703 EcoModding Central 3 03-07-2009 02:00 PM
