Old 04-05-2008, 01:25 AM   #21 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-05-2008, 01:52 AM   #22 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Toyota Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Toyota Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
look at da baby kittie!!!!!
your only seeing the clean pictures LOL
I had bugs on bugs on bugs on the front end till yesterday.
your definition of slammed is a bit off, mine is only a 2/3 stance vs stock..
heres my truck..
I just have some cheapo 16" wheels to drop weight..
thats actually a factory size wheel for my truck..
this illustrates "slammed" w/"rims" just for you Frank
slammed = tucking wheel/tire FYI..
I think "rims" in a cool factor start at least a 17" size to qualify as cool on at least a 50 series tire..
still very capable..
hard to keep it clean, but when it is.. at least once a month
Old 04-05-2008, 05:35 AM   #23 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
[QUOTE=diesel_john;17912]
Originally Posted by fabrio. View Post
A solution came from a self made air filter, like my work
fabrio. is that added in front of your stock filter?
The best thing I like about K&N is mice can't chew thur the steel mesh. I do use one the Vett race only.
But with the K&N my crankase vent system doesn't work as well on the diesel.
The vacuum pump doesn't work as well because it is hooked to the crankcase.
It doesn't filter the fine particles as well because my intake is getting dirty.
The K&N allows a louder intake noise on the diesel.
I did not gain any mileage improvement, if anything lost, because less crankcase vacuum.
quote""I would only use a non-paper element in somthing that could use the extra air flow (ie a diesel or performance car)""
More air won't help if I am already running an air/ fuel ratio of 100 to 1.
quote""I'm going to try just using my air compressor and blowing the dirt out of the paper one from the back side (clean side).""
Most engine manuals warn against blowing out paper elements with any thing but low pressure regulated air, tapping the metal canister kind against a tire for xample is allowed on a combine harvester for example were I can get a pound (1Lb.) of fuzz in the trap in one afternoon.
I wish i had my $35 back on the one for the VW diesel.
I hold the paper ones up to the sun and if i can see light on every pleat, i put it back in. My big diesels have a sensor and a red light if the filter becomes too restrictive. Why not all cars?
no!
this self made foam air filter it replaces the original foam element.
It use, the foam from another airfilter, new steel mesh, the original filter's structure and black silicon for adhesive by materials.
Complete work, include, mods at external and internal snorkels, with new horn profile at mouth of intake tube.
total cost, about 6€ for the foam, e two hours of work (only for new air filter).
Old 04-05-2008, 09:53 AM   #24 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
Speaking of mice... I found one the other day in my engine bay while trying to replace my valve cover gasket. It was dead and didn't have anything to make it's nest cause it died from what I guess heat... it was found near the exhaust
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-06-2008, 08:15 AM   #25 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
http://www.amazon.com/gp/product/B000E5XQDY
Run a paper filter then replace whenever the minder moves. End of problem. You will be shocked how long you can run a filter with out much restriction.
These are just re-branded filter minders, if you want a ford, Cummins, Amsoil, etc just buy one of those they are the same other than the attachment system
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-06-2008, 10:32 PM   #26 (permalink)
Most people aren't concerned about restriction, it's mostly filtration. Power hungry guys are usually worried about restriction from the air filter. If you talk about not running a K&N cause they don't filter good enough but you don't change your filters for 60k or 70K+ miles, and you just shake the loose dirt off, how good is the filter filtering even after a good shake? That's just my question.
Old 04-06-2008, 10:39 PM   #27 (permalink)
EV OR DIESEL
Well, let me shock you (it surprised me at first)
Dirt is a Great filter!
In fact it catches dirt better than most things. Don't believe me? Check out K&N's literature, they state that their filters filter best with about 1/4" of debris build up.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
Old 04-06-2008, 10:42 PM   #28 (permalink)
MechE
A very good question indeed.... Something worth exploring in my opinion
I'm willing to run a test similar to the bobistheoilguy test But, my filter only has ~30K miles on it....
I would put the testing paper in for the old filter - then switch out for a new one and run the same testing miles.
Any suggestions?
Oh, I don't tap my filters - I just put a vacuum in the airbox to clear any dirt that fell off the filter into the bottom of the case (which is the filter inlet side). There's no particular reason for this
On another note - I've got oil analysis showing that the filter is working in it's current state (as per silica levels in my old oil)
Old 04-06-2008, 10:43 PM   #29 (permalink)
That's a lot of debris!!!
Old 04-06-2008, 10:46 PM   #30 (permalink)
MechE
Sure, but dirt is abrasive.... If the dirt is enlarging the holes in the filter media - is tapping it out necessarily a good thing?
This is an intriguing question... If we're empirically denouncing the k&n design - we should, at the very least, empirically test our own practices. Sure, the replaceable filter doesn't filter well - but that's not evidence that a 60K mile paper element does
It's not much (typically) We're talking a tiny bit of dirt stuck in the corners
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 63 03-22-2019 09:53 AM
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Home made air conditioning article Fudog1138 General Efficiency Discussion 9 11-24-2008 08:13 PM
DIY: tire bands for Air Pressure Sensors larrydag DIY / How-to 10 05-08-2008 01:30 PM
OEM Air Injection, Yay or nay? Dane-ger EcoModding Central 11 01-14-2008 10:05 AM
