Old 01-14-2013, 06:47 PM   #11 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
On my SGII / Civic I typically get about 55 MPG in the summer regardless of the route (<65mph intra-city routes that is) so I always choose a shorter route to get lowest number of gallons per trip.
BUT this is a skill I've honed with the SGII and I'm doing advanced hypermiling, DWB and extensive EOC, in a manual tranny. Without those techniques it's possible for a shorter city route to yield higher total gallons, although even being minimalistic, DWB and engine-off at lights, mpg shouldn't be too different between city and highway. Neutral-gliding or P&G on downhill also neutralizes the effect of the hill, even without EOC.
Hills and lights are mostly non-issues for me unless there is some loss that can't be avoided, i.e. downgrade too steep or a stoplight at the bottom of a hill or a downhill freeway off-ramp, requiring brakes or engine braking, etc. Even then it sometimes just averages out.
Eco-driving can be done wrong though. Owning a gauge is money.
Old 01-14-2013, 07:00 PM   #12 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
There is a formula...how long is your route? you need to figure out the percentage...if the longer route is 5% longer and you can get 5% better fuel economy then you are breaking even...but if it's 5% longer and you get 10% better fuel economy then you're saving fuel.
I know you don't have instant feedback so it's hard for you to figure out what fuel economy you are getting on the different routes but i can almost guarantee it's always cheaper to go the shorter route
The Following User Says Thank You to GRU For This Useful Post:
razor02097 (01-18-2013)
Old 01-14-2013, 07:13 PM   #13 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
It's 27% longer. My daily commute isn't that far. It is 64% highway and 36% city.
Project Avalon: E bike build
Last edited by razor02097; 01-18-2013 at 11:51 PM.. Reason: Updated numbers after doing calcuations.
Old 01-14-2013, 07:18 PM   #14 (permalink)
90 day: 19.36 mpg (US)
The number of full stops is the killer. Not so much a penalty on the gasoline go-karts as compared to diesel trucks of any size, but it is still there. Wear & tear is cumulative over tens of thousands of miles. That is still the metric about saving money.
The heavy subsidization of fuel in this country makes chasing a few tiny tenths nearly meaningless. It's the cost of the vehicle over X-miles and Y-years that is the starting point. Extending the life of a vehicle over several more years is where true savings are found. Fuel cost is just one of a couple of variables under control of the driver. The rest is a fixed game.
Old 01-14-2013, 09:04 PM   #15 (permalink)
christofoo's Avatar
I've put a lot of thought into this and I disagree on the economic bit. At least - in the context of the cars that I drive.
My Corolla in the 220k neighborhood:
$0.08 per mile repairs + maintenance over the last 33k
45MPG @ $3.6/gallon = $0.08 per mile (28MPG = $0.13/mile)
(I'm pretty sure the wife's Civic now in the 150k neighborhood has been significantly lower than that in repair $ per mile for the last 50k, but I haven't actually tracked it.)
(Razor never said it was about money. For all we know he wants to minimize CO2.)
Old 01-14-2013, 09:27 PM   #16 (permalink)
razor02097's Avatar
Post #7 sorry...
Don't get me wrong though all of the emissions equipment has remained operational on this vehicle. I maintain and repair any that fault. So I am obeying federal law and doing my part to keep the EPA happy.
Old 01-14-2013, 11:08 PM   #17 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Another aspect to consider is the accident potential of each route. If you are trying to coast up carefully to keep an even speed, and avoid a full stop at any of the lights,
someone less patient will invariably have some kind of conflict with you.
Pennies difference will mean little if your car gets hit, or if you are constantly being
flamed by other drivers.
I think it is easy for you to see I vote for the longer road with peace of mind!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!![SIGPIC]
Old 01-18-2013, 08:26 PM   #18 (permalink)
razor02097's Avatar
Well after 3 tanks the vacuum gauge has net me an extra 1.5MPG average. I went ahead and ordered a MPGuino from JellyBeanDriver. I have the ability to datalog right now but there isn't any real time easy numbers I can look at for efficiency other than the injector pulse width.
Something else I did was to install a brake light button for 2 reasons... 1 people here get right on your ass and don't pass you. I can hit that button a few times to act like I'm slowing down so they get in the left or center lane. The other reason is engine braking. People in their automatics don't know what that means and plow in to the back of you. When I exit the freeway I can engage DFCO and push that brake light button.
Here it is...
When the brake lever is down I just rest my hand on the hand brake and push the button.
Old 01-18-2013, 11:21 PM   #19 (permalink)
XYZ
What is your typical speed on the short route, excepting having to stop for lights or slow for traffic?
The trick is to stay in a relatively high gear for as long as possible. If you are at near highway speeds (above 40 MPH) for most of the short route, that is the most economical option - even though the long route may be less stressful driving.
Old 01-18-2013, 11:47 PM   #20 (permalink)
razor02097's Avatar
The short route is 2.1 miles. Average speed over the short route in a 15 day spreadsheet record is 19.6MPH @ 6 minutes 25 seconds. This was calculated by taking the average of the speeds and times over the 15 day period. This route includes 5 stop lights that are poorly timed, a small ascending grade and a large hill. I can time the lights but it takes a lot of throttle which is inefficient.
The long route is 5.7 miles. The average speed over the long route is 41.6MPH @ 8 minutes 13 seconds. I only have 3 data points so far (3 days). This route has only 1 stop light. There is a small descending grade initially then it flattens out the rest of the way.
I can keep a much higher average speed here but it takes about 2 minutes longer and I have to travel 3.6 miles further. It might not sound like a lot but it is more than two and a half times the distance of the short route.
