Old 01-27-2010, 09:02 PM   #31 (permalink)
EVVette - '71 Chevy Corvette Coupe
Huh...That is interesting.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 02-01-2010, 11:41 AM   #32 (permalink)
jackbauer's Avatar
Ok probably a stupid idea but here goes. today i had a scare when the throttle stuck wide open. Not a failed controller. Could we have a large button or a keypress that immediatly commands zero throttle regardless of input?
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 02-01-2010, 11:48 AM   #33 (permalink)
The best I can think of would be a button that would send a "bat-amps-lim 1" command that would tell the controller that it cant draw more then 1 battery amp. This would slow you down really quick.
-Adam
Old 02-01-2010, 12:04 PM   #34 (permalink)
bones007's Avatar
If you keep the clutch you can press it to the floor fast - essentially separating the motor from the wheels. The over-rev protection should keep the motor from exploding and you can use the brake to stop as quickly or as slowly as you like. Once you are stopped just turn the ignition off to open the contactor.
In my opinion this would be a more natural reaction for a driver than reaching somewhere for a "kill" switch. Although, adding a switch too is probably a good idea.
Old 02-01-2010, 12:17 PM   #35 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
I think that a "Kill Switch" should be mandatory in any type of experimental Electric Vehicle; if it is at the controller level protecting the motor for over-rev it, would be fine.
Usually, a "Kill Switch" is installed first on line after the traction battery power source to the vehicle.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 02-01-2010, 12:39 PM   #36 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Any panic button should basically disconnect the battery pack and not rely on the cpu being able to respond to commands. I.e. interrupt the contactor, but physically separating the contacts is even better. I like how Darin reused the clutch pedal for this especially (plus redundant contactors on key and pedal up).
it starts about 1:50, clutch is at 2:07
Old 02-01-2010, 12:56 PM   #37 (permalink)
AC-DC enthusiast
mrbigh's Avatar
About the "ForkenSwift" clutch safety disconnect, it's a nice concept, for clutchless vehicles, but also a big concern in case of a common mistake of pressing the clutch pedal while in motion, in this case will be an Anderson's contact burner because of arcing at disconnect, but I guess it will be on the driver's ability NOT to play around.........
Safety measures are never to redundant in my book.
Old 02-17-2010, 10:06 AM   #38 (permalink)
hy
i am using RTD Explorer on an panel pc built from an eepc
this unit has 800x480 display
RTD Explorer crashes often unless is set to full screen
can you help and set an smaller resolution
thanks
Old 02-17-2010, 11:55 PM   #39 (permalink)
Originally Posted by jerpelea View Post
hy
thanks
Can you provide me with some more information about the system? Processor, Speed, Amount of Memory.
Also would you be able to get a screen shot of any errors that come up?
How does it crash? Does it just close, or does it hang and you have to kill the process? What OS are you using also.
-Adam
Old 02-18-2010, 01:59 AM   #40 (permalink)
-Adam
hy Adam
thare is no error
application just closes itself
if i can maximize it untill it closes it works
ASUS Eee PC - Wikipedia, the free encyclopedia
xp sp3 with net framework 3.5
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
