Old 03-06-2018, 06:56 PM   #41 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
A side thought related to large engine for good MPG... I used to have a 1995 Ford Ranger, 2wd, 4.0/manual with 3.08 gears... even with those gears it really could move out(225lb/ft TQ at 2600) and driven sanely I seen low-mid twenties (high of 25mpg) and now that I think about it, I never hypermiled it at all... maybe going up to a 2.73 gear(and adding limited slip) and some aero mods it coulda done 30mpg with ease and still done all the truck stuff I used it for...
My current Ecotec project...
My last Ecotec project...
Old 03-06-2018, 08:47 PM   #42 (permalink)
ALS
Volvo 940 non Turbo a 94 or 95, they came with a 2.3 Liter motor and automatic transmission.
You said you're driving mostly on the highway and at sane speeds 65 mph they will consistently pull low thirties like, 32-33 mpg on the highway.
Cheap to buy and easy to maintain. Those red block Volvo motors will easily last 250K with oil changes and timing belt changes.
Can be had cheap, Checked the Craigslist by me and there is a 94 with 105K miles on it for $1,450. Stay away from the Turbos, most are beat and highway fuel mileage is in the 25-27 mpg range
The Following User Says Thank You to ALS For This Useful Post:
jkp1187 (04-15-2018)
Old 03-06-2018, 11:22 PM   #43 (permalink)
357
'96+ BMW 318i sedan or coupe (which i think was exclusively called the 318is)? I think somebody eluded to those early in the thread. They're rated right at 30mpg highway, but you've got a lot of options to play around with the final drive ratio. Manuals came with a 3.46, Auto's with a ludicrous 4.44, and there are ratios available all the way down to 2.93 (my advice would be to just buy an entire used diff of the desired ratio--it'll likely be less than $100). Easily available for less than $3k from what i've seen, and generally in better shape than a comparably-priced 6cyl car, since they just aren't powerful enough to be thrashable.
The Following User Says Thank You to 357 For This Useful Post:
Old 03-07-2018, 12:12 AM   #44 (permalink)
Dark Egg - '12 VW Touraeg
I wonder what makes that BMW a "mechanics special" That car is smoking awesome for $2600.
oh here is the dealer's page http://www.dorianford.com/used/BMW/1...4a23c84612.htm
Old 03-07-2018, 12:31 AM   #45 (permalink)
Neither do I, but in my country there is a trend of swapping engines from Volkswagen and Chevy into old Bimmers when their original engines have been so poorly mantained that it becomes cost-prohibitive to fix them properly.
Old 03-07-2018, 04:14 AM   #46 (permalink)
Smokey - '13 Chevrolet Cruze Eco
I don't see me driving a beemer, although they do look good.
Old 03-07-2018, 04:49 AM   #47 (permalink)
LeanMeanGreenMachine - '95 Toyota Tercel DX
90 day: 47.67 mpg (US)
TurboQuattro - '89 Audi 200 Turbo Quattro AWD
Last 3: 33 mpg (US)
DeathTrap - '94 Ford Escort LX
Last 3: 36 mpg (US)
CreamPuff - '96 Dodge Stratus
90 day: 27 mpg (US)
hoopdy - '88 Toyota Camry
90 day: 30 mpg (US)
My '87 BMW 325is e30 would get 27mpg on the highway. A 318 can get into the mid 30's mpg.
Old 03-07-2018, 04:57 AM   #48 (permalink)
Last 3: 33 mpg (US)
Last 3: 36 mpg (US)
90 day: 27 mpg (US)
90 day: 30 mpg (US)
haha. just saw your post after I posted. They really are good cars in the '90's until you start having to worry about automatic slushboxes and double vanos intake seals in later models--you really can't go wrong with a straight 6 without double vanos. An early '90s 525i or 528i wagon, for instance, I believe is one of the best used cars out there. They are easy and inexpensive to maintain.
Old 03-07-2018, 05:29 AM   #49 (permalink)
Meanwhile, in another subforum...
http://ecomodder.com/forum/showthrea...ild-36203.html
jackbauer has taken the bull by the horn.
Three conspiracy theorists walk into a bar --You can't say that is a coincidence.
Old 03-07-2018, 01:29 PM   #50 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Used BMWs may lure you in with their low asking prices, but maintenance and repairs can quickly make that shoot up.
My experience working on BMWs has been pretty bad. Recently I tried to help out a friend of my little brother with his 325i that had a bad thermostat. It turns out that the automatic transmission versions have an additional fan, a mechanical fan that gets in the way of thermostat replacement and is not straightforward to remove. I spent a few hours trying to get it out, but there was one bolt that I couldn't get to, and I couldn't remove the fan, so I put it back together and gave up. He had to get it replaced at a mechanic, and then later it blew a head gasket(probably related to previous overheating).
Previously, a friend and former coworker had bought a 325i of the same generation as the one in the story above, this time with a manual transmission. It had a blown head gasket that wouldn't allow him to leave the radiator cap on when cold, so he had to warm the engine up then put it on. I had never driven an inline 6 car before so I wanted to try it out. Battery was dead of course, so we went to bump start it. I went to shift into gear and it didn't do anything! Of course the moment I get in the car the shift linkage disconnects.
Even less recently, I had a 325i come into my workplace that was all sludged up at 60,000 miles. I used to want one of these little inline 6 BMWs, but these experiences have made me re think that decision. Unfortunately I can't convince my little brother otherwise, he still wants one.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
