Old 09-18-2009, 09:52 PM   #1 (permalink)
toyota corolla - '99 toyota corolla ce
90 day: 38.97 mpg (US)
An simple idea : heat gaz
Hi ,
here in quebec , in winter we hit -30 degree celcius ... car milleage goes worst . But what is the différence with summer ? gaz is cold , air is cold , (engine still warn up ) ... so we can put a hot air intake but should it be possible to heat the gazoline before going to the injector or there will be condensation ?
just a simple idea ... ex: turn the line over the manifold or radiator hoses ?
graphic:http://ecomodder.com/forum/em-fuel-l...vehicleid=3083
lowered -1.5 inch .
+80 pound (approximation) of audio (and draw a max of 20-25 amp approx..)(ouch for alternator !!)
Old 09-18-2009, 09:55 PM   #2 (permalink)
You'd be better off making sure you always have the stereo on full blast; that will vibrate ice crystals in the fuel into smaller ice crystals that are easily passed. Also the vibration raises temperature in liquids so there ya are, multiple great benefits of cranking that stereo as high as it will go. Make sure you select tunes with much bass so that you can spread the joy even further.
As far as some other way of heating gaz, I've never heard of that and I've been obsessing over this for a long time so I'm pretty sure it's never been done.
Old 09-18-2009, 09:58 PM   #3 (permalink)
heeem not sure ...
200 rms is not enough for that
is that theory a joke ?
lowered -1.5 inch .
Old 09-18-2009, 10:32 PM   #4 (permalink)
Maybe your... amp isn't big enough?
Old 09-18-2009, 11:00 PM   #5 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
20 amps at 12VDC (conservative figure) is 240W... if you're only getting 200W, you're losing a great deal of signal somewhere.
Old 09-19-2009, 02:29 AM   #6 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Heating gasoline and/or intake air has been discussed here before. The biggest reason for low mileage in winter is that the air is denser and gives more drag. Other factors are road surfaces and running rich during warm-up. Use a block heater even if starting is easy.
Old 09-19-2009, 02:49 AM   #7 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
homogeny
Old 09-19-2009, 08:07 AM   #8 (permalink)
Ha okay , thanks for complete answer
lowered -1.5 inch .
Old 09-19-2009, 08:08 AM   #9 (permalink)
HEee ... why should I have 20 amp ?
hey my amplifier is a 200 watt rms ... thats it ... 15 amp
lowered -1.5 inch .
Old 09-19-2009, 10:58 AM   #10 (permalink)
In your sig, it says 20-25 amp... I went with 20.
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 56 06-12-2011 03:09 AM
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Electric car heat! Liquid? bennelson Fossil Fuel Free 38 12-11-2009 10:59 AM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
