Old 02-03-2009, 12:10 AM   #1 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
Spark plugs
What does it indicate, if when you pull a plug, the threads are oily, and some oily sludge exists slightly outside of the compression ring, in a situation where the plug boot fully seals around the plug hole? (The plug hole was clean otherwise, so this didn't seep in from outside).
Old 02-03-2009, 01:54 AM   #2 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Who did the last plug removal before yours and why did they do it?
As sloppy mechanic doing a wet compression test?
Old 02-03-2009, 02:07 AM   #3 (permalink)
That would be me. I'm fairly certain I got the plug in tight at that time. The compression ring was crushed anyway, and the plug wasn't removed after that until it's recent replacement.
Old 02-03-2009, 07:35 AM   #4 (permalink)
It was just a shot. Couldn't think of an obvious mechanical explanation, so I looked for human intervention. Could it have been a spec of crud under the compression ring preventing a 100% seal?
Old 02-03-2009, 05:35 PM   #5 (permalink)
Hard to tell. The sludge only went slightly past the ring, there wasn't very much on the metal body at all and none as high up as the nut, but the ring itself is completely sludged over.
Old 02-03-2009, 06:21 PM   #6 (permalink)
If the bottom (mating) surface of the ring is gummed up with sludge, it must not have had a good seal. If the ring is crushed, there must have been something trapped under the ring when it was seated. No?
Old 02-04-2009, 01:27 PM   #7 (permalink)
Quite probably. I just can't find it in all the sludge.
Old 02-04-2009, 02:48 PM   #8 (permalink)
Are you sure it's oil sludge and not some decomposed anti-seize compound?
Old 02-04-2009, 03:19 PM   #9 (permalink)
Gustavo.Almeida's Avatar
These were my plugs. The problem? My thermostat was cooling in excess, making the mixture too rich.
'96 Rover 216 Coupé
Old 02-11-2009, 05:10 AM   #10 (permalink)
There wasn't any anti-seize on the factory plug, and I didn't use any when I changed the plug. That second plug I pulled out had the sludging problem.
Platinum NGK Spark Plugs vb_bn General Efficiency Discussion 22 05-05-2010 10:03 AM
DIY - Spark Plug Indexing SVOboy DIY / How-to 40 05-21-2009 12:58 PM
New set of Denso Iridium Spark Plugs ... cfg83 Success Stories 11 02-20-2009 04:33 PM
Green spark plugs? WhenGrantAttacks EcoModding Central 3 07-11-2008 05:10 PM
Halo Spark Plugs DifferentPointofView EcoModding Central 1 01-28-2008 11:13 PM
