Old 03-14-2008, 03:43 PM   #11 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I think that's because the car has quite a bit of "cab forward" design to it - ie. the mirrors are probably the same position relative to the driver as they are in most cars. Just a guess.
Old 03-14-2008, 04:24 PM   #12 (permalink)
Who
UnderModded
Pablo - '07 Hyundai Santa Fe AWD
90 day: 23.62 mpg (US)
I would have guessed the mirrors are back farther for aero reasons - seems to my very non-professional eye like they'd cause far less drag there...
Old 03-14-2008, 04:37 PM   #13 (permalink)
H4MM3R's Avatar
.137 Cd
1985 Ford concept with a Cd of .137
ID:	458   Click image for larger version
Old 03-14-2008, 06:03 PM   #14 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
Originally Posted by basjoos
I thought the lowest Cd for a ground vehicle was 0.11, which is what they claim is the Cd for the Aptera.
All the texts I've read (Hoerner, Hucho, an SAE symposium, and another) claim that 0.15 appears to be the lowest cD for a blunt body, w/ wheels, in ground effect. In the symposium, one professor argued that cD could be lowered further by removing vehicle lift, but the issue was contentious. This was all before CFD, though (1970's).
The lowest theoretical drag shape near ground effect (w/ out wheels) was a shape very similar to the Aptera (~0.09-0.11 mark). The Aptera's wheels are far from aerodynamically clean (two control arms in the breeze). Solar cars supposedly have a cD of 0.09, but they don't seem like blunt bodies to me.
I should add that these might have been 2d shapes (i.e. infinite span). 3d shapes can have lower drag. If that is the case, sorry for being misleading.
I believe a slippery slope some might be falling into is claiming cD*A as cD, which is often done and easily confused.
- LostCause
Old 03-14-2008, 06:29 PM   #15 (permalink)
Liberti
LostCause's Avatar
That car looks more similar to the ideal 0.15 shape than a real car. Either the art has progressed (likely), cD*A is being claimed (possible), or we are getting into an issue of semantics (likely). I assume a body is defined as being blunt @ a certain fineness ratio. Also, I don't believe 0.15 was ever believed to be an impenetrable barrier, just a likely limit.
From memory, the ideal 0.15 car and ideal 0.09 GE shape:
Good contributions.
- LostCause
Old 03-14-2008, 08:59 PM   #16 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by LostCause View Post
Food for thought: the lowest cD of a wheeled vehicle in ground effect - ~0.15
- LostCause
Vector-One
cD = .1 even
Frontal Area = .42 m^2
Varna Diablo
cD = .11
Frontal Area = .183 m^2
Virtual Edge
cDA = .011m^2 (don't have the actual cD value)
All of these are wheeled land based and close enough to experience the ground effect (at least, they are designed to work with that - except for the Diablo which was just sculpted - tested later). I'm only showing human powered ones because a great deal of effort has been put into achieving ridiculously low cDA values
Generally, it's not a good idea to place limits on "best" 400 years from now, when the star trekian force field is perfected - we'll have the ability to have cD values of .0001 and under etc.
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 03-14-2008, 09:36 PM   #17 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 29.5 mpg (US)
90 day: 49.62 mpg (US)
Originally Posted by trebuchet03 View Post
[ 400 years from now, when the star trekian force field is perfected - we'll have the ability to have cD values of .0001 and under etc.
Larry Niven's "sonic fold" from Ringworld.
Old 03-14-2008, 09:46 PM   #18 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
notice the angled view, the photos never show an x,y,& z view. and you all know why, cause we would have it on our cars faster than you can say, (alt. print screen, paste).
Old 03-14-2008, 10:28 PM   #19 (permalink)
MechE
Originally Posted by diesel_john View Post
... all cars would look the same ...
They don't now?
Sure, they have their subtle differences... Just like the streamliners I posted above... But, they look very much the same (other than the Mazda perhaps - it has a smile sort of look from it's grille)
I see no reason why we can't have variation and low drag - for instance
and
-Images ripped for all over the internets
Old 03-14-2008, 10:35 PM   #20 (permalink)
H4MM3R's Avatar
That VW is Sweet!
