Old 12-10-2016, 12:05 AM   #11 (permalink)
I bet it doesn't really need much to stand out from the crowd anyways...
Old 01-11-2017, 06:41 AM   #12 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I already suspected as much based on my Fiat 500 (which also has a tiny turbo engine) that P&G doesn't work for a car like this.
But today I had a bit of time to kill so I thought I'd prove it.
I have a ~4mile test loop, it circles a lake so it's pretty flat and being a loop cancels out any wind assistance, not that there was any. There are three sets of traffic lights on the loop but I pretty much caught one red per loop so they roughly cancelled out.
Weather was in the 35*C range, auto A/C on, target speed 74km or 46MPH. Accelerating at 80% load.
First loop, constant speed SGII reported 5.35l/100km or 44MPG, also recorded the highest AVG speed.
Next up was P&G using DFCO, that netted 6.9 or 34MPG
Finally, P&G using neutral coast, that netted 6.4 or 37MPG, however at the lowest AVG speed.
The clear winner is the steady state cruise, you'd want to run the test a number of times before deciding between DFCO and neutral, I literally can't feel the difference when I put the clutch in and a closed eye passenger couldn't either. The van uses a relatively large amount of fuel when in neutral as it idles at around 1.3-1.7L/hr.
EOC isn't possible with the push button start.
At a steady 74km/h I was averaging 3.8l/100 or 62 MPG US
The Following 3 Users Say Thank You to oldtamiyaphile For This Useful Post:
Daox (08-03-2017), freebeard (01-11-2017), Joggernot (02-26-2017)
Old 02-25-2017, 11:20 PM   #13 (permalink)
Team Turbocharged!
Pickups
I changed out the factory fill oil at 3260km, ideally I'd have done it a bit sooner, but you know...
When I removed the undertray, I was able to have a bit of a poke around under there.
First thing I spotted was the in line electric water pump to cool the turbo after shut down (the actual water pump is a variable geometry design). This explains why I can hear a whine much like the Prius inverter pump after shut down:
It seems that this would be a good idea for anyone with a turbo doing much engine off stuff. My Fiat has factory S/S and no such pump!
Electro-Hydraulic Power steer pump. This explains why the steering works with the engine off, but it feels like hydraulic steering:
Could be useful for swaps into bigger vehicles where the Toyota MR2 pump might be insufficient. I didn't look into how complex the wiring is, but probably not as simple as the Toyota three wire hook up.
ID:	21332   Click image for larger version
Old 02-26-2017, 12:52 AM   #14 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
That electric water pump cooling the turbos after shut-off is one of the best ideas I've seen implemented yet.
Old 02-26-2017, 02:09 PM   #15 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 10.61 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 18.41 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.7 mpg (US)
I don't know about the push button on this van but on
Ford 's, you push and hold till engine shuts off while coasting
Staying Focus'd on MPG
Old 08-02-2017, 09:53 PM   #16 (permalink)
Team Turbocharged!
Pickups
Discussion thread:
http://ecomodder.com/forum/showthrea...tml#post546507
It's amazing given all the affordable tech available these days, how few people are curious enough to actually test things, instead of going by 'what always worked' etc.
Since I do my own tinting and my van has two identical rear windows side by side, I figured I owe it to my own curiosity and Ecomodder to test my window tint for myself.
Here are the specs for my lifetime guarantee USA made film (I think Johnson & Johnson brand).
UV Rejected 99%
Visible Light Transmittance 20%
Visible Light Reflected- Exterior 5%
Visible Light Reflected- Interior 5%
Total Solar Energy Rejected 58%
Conditions, sunny winters day 15*C ambient, taken at midday (rear windows facing north).
Interior/Exterior Glass surface temperatures:
Black MDF shelves left inside to simulate a dash board etc:
So an 8*C temp reduction for about a $50 investment
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
Daox (08-03-2017), freebeard (08-02-2017)
Old 08-02-2017, 11:16 PM   #17 (permalink)
Interesting. I could use some on the window I'm sitting next to right now. It's 102°F (38.89°C)
How much material did you get for that $50?
Old 08-02-2017, 11:41 PM   #18 (permalink)
Team Turbocharged!
Pickups
$50 buys about 6m (20') of film at around 600mm (2') wide. House windows are really easy to do, car windows take a bit of practice, so I'd recommend buying double what you actually need, if you've never done it before, depending on how tricky your windows are.
freebeard (08-03-2017), Xist (12-20-2017)
Old 08-03-2017, 11:11 AM   #19 (permalink)
I'm thinking of an Airstream trailer, one roll would do all 12 windows.
Old 12-20-2017, 09:09 PM   #20 (permalink)
Team Turbocharged!
Pickups
Minor update. Record commute this tank.
4.6/100km or 51MPG US city.
Not bad for 2+ tons.
When I refilled my tank SG calibration was spot on so that's a fairly accurate number.
The two way average for the day was still an impressive 5.3, or 44MPG.
The tank itself was a fairly average 6.8, that's the effect of the summer heat.
Daox (12-21-2017), Joggernot (12-21-2017), MetroMPG (12-21-2017)
