Old 07-07-2013, 05:52 PM   #1 (permalink)
Streamlined Citroen ZX
Good day, ecomodders!
Here is my latest project - Citroen ZX.
This was actually the experimental part of my master thesis. I needed to analyse how drag affects a moving vehicle and how it's aerodynamics could be improved. So here is what I did. Firstly I created a rough model using Autocad.
Then tested it with Autodesk CFD Project Falcon
Then did the modifications and here is the final model
Put it in the CFD and got a Cd of 0.23
NOW here is the interesting experimental part. The build began from the underside. Policarbonate and sheet metal was used
Then the boat tail construction started
Boat tail underside made from textolite
First test run early in the morning
Tuft testing
Covered the rear wheel arches, partially blocked radiator ventilation and covered the fog lights + some final touches. And I give You the final result
The summary
The master thesis was graded as almost perfect. So first mission accomplished. Due to the lack of time and money the detail of this project could have been better.
Currently I've removed all of the mods to adjust the brakes fix the clogged exhaust system and to make the car mechanically sound so to pass the mandatory checkup.
The fuel consumption
Orginal car ABA testing did 31.36mpg @ 56mph (speed limit).
Modified car same road same speed but warmer weather did 49mpg. This mpg increase is very close to the one that was theoretically estimated. Yet currently Citroen without the mods is showing a significant increase in mpg compared with the old testing. This might be due to the exhaust system fix and the warmer weather we are having right now.
Future plans
Make the boat tail shorter and more practical. Connect to the ECU to take control of the fuel mixture.
If you took the time to read this
You are awesome.Feel free to like and share my FB page. http://www.facebook.com/flylowlt
Last edited by CitroX; 01-10-2016 at 07:29 AM.. Reason: Pictures from imageshack gone missing, just re uploaded some of them. They can also be found on my fb page which you can find in my profile description
The Following 22 Users Say Thank You to CitroX For This Useful Post:
AndrzejM (07-12-2013), Arragonis (09-24-2013), ausias (09-23-2013), BamZipPow (11-07-2013), California98Civic (09-17-2013), Cd (07-12-2013), christofoo (09-25-2013), DFBVT (11-08-2013), ECONORAM (08-16-2014), Frank Lee (07-07-2013), jime57 (11-07-2013), Joggernot (11-08-2013), JRMichler (07-07-2013), Jyden (07-08-2013), MetroMPG (08-29-2014), NeilBlanchard (09-18-2013), pgfpro (09-14-2013), Piwoslaw (07-16-2013), renault_megane_dci (09-19-2013), sheepdog 44 (07-07-2013), sully06 (07-07-2013), Xist (09-17-2013)
Old 07-07-2013, 09:12 PM   #2 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Warmer weather definitely improves mileage. My sig line has some numbers.
Old 07-10-2013, 05:25 PM   #3 (permalink)
I started to put the car back together today. Since I have a bit more time now I can test more modifications individually. But before putting the flat bottom back on I've decided to see what difference in mpg would a front splitter make which I had laying in my garage from a rs fiesta.
Old 07-11-2013, 05:31 AM   #4 (permalink)
I forgot to add tuft testing of the final model in the first post. Unfortunately the camera focused on the windscreen when we were filming yet the tufts are still visible. The mods did a major difference in airflow.
Old 07-12-2013, 05:11 AM   #5 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Nice project! I like it! Do you think that you don;t have trouble because of a boat tail from the cops?
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 07-12-2013, 10:37 AM   #6 (permalink)
2013 Matrix 2ZRFE - '13 Toyota Matrix
90 day: 38.48 mpg (US)
Hi,
wow you have done a lot of work on this car.
If you want to modify it, I suggest you to make it narrower at the back. It will be better with side wind.
Old 07-12-2013, 11:25 AM   #7 (permalink)
It is allowed to have one meter+ of cargo to be sticking out of the car as long as it is secured, marked and not draging or anything
Hi, wow you have done a lot of work on this car.
I will try to redesign it a bit. I'll see what kind of a compromise i can work out. And I want to make the whole thing neater, use less white wrap
Old 07-12-2013, 05:49 PM   #8 (permalink)
Cd
Ultimate Fail
Cd's Avatar
You did a fantastic job not only with the car, but with your post here on EM.
All the information is nice and neat and you did all the testing that is usually done and showed your results.
The final results look very much like a factory show car from the 1980s back when good aerodynamics actually brought bragging rights.
Old 07-13-2013, 09:13 PM   #9 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
Great work and welcome to ecomodder
Old 07-14-2013, 07:28 AM   #10 (permalink)
Wow,I knew that ford sierra was aerodynamic at the time but this prototype is full of 80's goodness. That is some good inspiration for the project and it has the wheel fairings which I would like to install.
Thank's Mike
The Following User Says Thank You to CitroX For This Useful Post:
euromodder (07-14-2013)
