Old 02-02-2009, 07:41 PM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Sunfire headlights are stoopid!
GRrr - Rant - Pontiac Sunfire headlights are stoopid!
My wife's headlight went out the other night, so I stopped by the auto parts store today while I was running errands.
To replace the bulb, you have to remove the entire headlight assembly. To get to that you have to first remove the radiator cover.
Once I made it down to the headlamp assembly, the second bolt (of the two that hold the headlight in place) slipped out of my hand and down into the gaping hole left from the headlight not being there.
Instead of falling straight to the ground, this car has sort of a mini-partial belly pan on just the sides. I have no idea if the bolt is in there or not. I whacked the bottom a few times, to hear if there was a bolt rattling around or not. Couldn't find it anywhere.
And could the Sunfire use a normal bolt to hold the headlight in? NOOOoooooo. It has to be a weird special bolt which I can't match.
So now, her car has two working headlights, but the driver side is only held in by one bolt.
Grrrrr...
End Rant.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 02-02-2009, 08:15 PM   #2 (permalink)
User unfriendliness.
This is what happens when engineers don't know how to turn a wrench.
I yoosta work in an Eng. Dept. and I think out of 200 guys I was the only one that changed my own oil and did my own mechanic work. Go figure.
Old 02-02-2009, 11:01 PM   #3 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I feel your pain
http://ecomodder.com/forum/showthrea...dure-5362.html
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 02-03-2009, 08:44 AM   #4 (permalink)
2k2Prot5 - '02 Mazda Protege5
90 day: 33.82 mpg (US)
I'm an engineer - i can assure you that the decision was made because it got the parts through the assembly line as cheaply as possible. I'm sure some consideration was made to the over-priced dealer maintenance people. They don't care about you and your troubles replacing the headlight.
Also, as an engineer... that pisses me off. It is money-driven.
Old 02-03-2009, 12:27 PM   #5 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Mine are just difficult to reach, but don't require removal of anything. It'd be a lot easier if I removed the battery and battery box, but I have thin enough hands to maneuver in there.
That's like my mother's old '92 Grand Prix with the battery under the washer fluid. "Sorry, I can't help jump start your car because I need a frikin' floor jack"
Old 02-03-2009, 12:52 PM   #6 (permalink)
I had a dead car one cold morning and i couldn't bump start it. A pontiac pulled up and offered a boost, but he had never done it before... lifted the hood, no battery to be seen. After scratching out heads a while, he wished me good luck and drove off. It was a newer car, too... STUPID design.
Old 02-04-2009, 01:08 PM   #7 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Thankfully I don't have a car that has a procedure that difficult. All my Pontiacs have headlight bulbs that can be changed without any tools. Snap out the grille with flip levers. Pull out the headlight assembly with two thumbscrews. Tailllights on the Celeb come out with thumbscrews. They don't build em like they used to.
Winter daily driver, parked most days right now
Summer daily driver
Old 02-04-2009, 02:51 PM   #8 (permalink)
I actually replaced a bulb on my Focus this weekend and was shocked to find that it was a very simple, toolless process. Just unscrew a cap, flick a wire clip, and unplug. This may be the first thing about this car that makes me really happy.
Old 05-01-2012, 07:13 PM   #9 (permalink)
Focus should be called Ford S/B...Surprise Box
Wait until rear suspension bushings goes,control arms/links needs to be replaced + wheel alignment = Katching!
BTW the coil springs are most likely broken at bottom,but can't see until removed.
I have a 98 Sunfire 2.2L and that's the only thing silly to work on so far...
Headlights tends to die due to a fragile ground wire that breaks.
Fun/easy car to work on
If i could only find out about a possible 5th gear swap...
Old 05-02-2012, 10:29 AM   #10 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I'm supposed to remove my front fascia to get at the bulbs. Riiiight. Of course if you can't see what you're doing very well because you're doing it with everything in place, then you just might break a retaining spring. That's only serviced as a headlamp assembly. My right low beam bulb has been held in place with mechanic's wire for the last four years.
Transmission type Efficiency
100+ hypermiling / ecodriving tips & tactics MetroMPG Hypermiling / EcoDriver's Ed 457 02-11-2022 03:57 AM
DIY LED Headlights SVOboy EcoModder Blog Discussion 44 09-06-2011 07:48 PM
Wanted: Metro Headlights Demon-Hemi For Sale 3 04-21-2009 09:28 PM
LED headlights are here! orange4boy EcoModding Central 5 09-30-2008 01:41 PM
Geo Headlights SirKeats Aerodynamics 10 05-23-2008 01:09 PM
