10-08-2009, 03:41 PM
#11 (permalink)
Dartmouth 2010
Originally Posted by racprops
So which is best Super MID or MPHGuino??
and how much and how to get a SuperMID??
Rich
I would go with the MPGuino, because it'll be easier to get your hands on and cheaper, though it doesn't have as many shiny features as the superMID.
11-21-2009, 03:27 PM
#12 (permalink)
Ultimate Fail
How are the settings on the SuperMID affected by changes in the condition of your engine, weather and other factors ?
I had my SuperMID set accurately at one time or another, but now the thing is all jacked up.
Also, ( I know I asked this before ) I'd like to set my SuperMID to read accurately, but I don't know my present FE.
Without going through a full tank and several hundred miles just to get my FE, is there any way to set this thing to read accurately ?
Thanks guys
12-13-2009, 06:19 PM
#13 (permalink)
Ultimate Fail
bump
10-10-2010, 03:34 AM
#14 (permalink)
Tiny - '90 Honda CRX HF Last 3: 55.97 mpg (US)
So how do you get a hold of one of these super mids? I just recently bought a '90crx hf and am frantically trying to find ways to improve mpg's to make the most of it. Currently at 53 mpg's regularly driving like a grandma with no serious alterations since I got the car. Can you help me?
11-21-2010, 07:29 AM
#15 (permalink)
1990 CRX HF unmolested
I also just bought a 90 HF on Saturday... would love to have a monitor but not a ton of time to R&D.. need a "turnkey" setup... has anyone seen detailed instructions on working install?
11-21-2010, 09:27 AM
#16 (permalink)
barchetta: check out the MPGuino subforum. Same idea as the MID, but more affordable and possibly easier to configure as well.
OpenGauge / MPGuino FE computer - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
PS: unmolested CRX HF? Envious.
11-21-2010, 09:44 AM
#17 (permalink)
Yeah with 155k miles on it too.. Only one modification.. an alpine stereo but stock speakers... I scored big time.. I wont tell you what I paid cuz you will be annoyed. I was patient and it paid...
I'll check the sub section.. I've determined a monitor is #1 way to get better MPG on an HF.. and I think I am right.. its all about the right foot.... I dont even know if I have cruise control (did any HF come with it?)... but I want to do a cruise based on throttle position... saw some messages about it.. I CANNOT BELIEVE manufactures are not doing economy modes on cruise control... although I have no hard data to indicate it would have as big effect on MPG as I think it would...
thanks
11-21-2010, 10:02 AM
#18 (permalink)
Yeah, don't tell me the price.
You're right that the nut behind the wheel is the quickest path to better fuel economy, but don't underestimate the power of instant/resettable MPG feedback to help you adjust that nut.
Have fun.
11-21-2010, 10:04 AM
#19 (permalink)
Have fun.
Thats what I meant.. the monitor is crucial to adjust your driving habit.
04-23-2012, 05:15 PM
#20 (permalink)
Ultimate Fail
I re-installed the SuperMID in my '93 Civic DX, but i'm not getting the speed setting to work. Any ideas on what i could have done wrong ?
I replaced the VSS with an aftermarket part, but I'm almost sure the VSS is identical ( electronic not mechanical ) so what could i have screwwed up ?
Coming from the VSS, there is a Yellow wire with a white stripe, a Yellow wire with a blue stripe, and a black wire which i assume is the ground.
Currently i have it wired to the Yellow wire with the white stripe.
I should mention that the readout for distance below average speed is working.
If there was a problem with the wiring to the VSS wouldn't the distance parameter no show ?
