Old 03-31-2016, 05:48 PM   #431 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
The trick is to flash an empty sketch to the TinkerKit LCD. The timing is a bit tricky but it works well enough. When I have time I'll see if I can make cheap units using an ebay arduino nano, a cheap eBay LCD, and a postage stamp of PCB for the BJT, zeners, and resistors. It looks like the minimum BOM is $8 without case.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
The Following User Says Thank You to H-Man For This Useful Post:
t vago (04-18-2016)
Old 04-14-2016, 07:00 PM   #432 (permalink)
Is there any reason I wouldn't be able to add some code to do an analog read of my dashboard lamp rheostat voltage and have the micro controller adjust PWM based on dashboard brightness?
Old 04-18-2016, 12:16 PM   #433 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Hardware-wise, you'd have to add a voltage divider to condition your instrument panel lighting signal to be less than 5VDC, then feed it to one of the analog input pins. You'd want to also add a 5 VDC Zener diode to the pin for circuit protection. The circuit would look similar to this:
The resistor values would have to be adjusted, but that should be easy enough to do.
Software/Arduino-wise, this capability could easily enough be added in. My code already has analog input reading capability built into it - not sure if the original DCB 0.86 (or earlier) code would allow/accept Analog library calls. I'd just have to provision in a way of assigning an unused analog pin for use with brightness.
I got the analog gauge driver code added in, but haven't been able to find any time to test it.
Old 01-05-2017, 06:19 PM   #434 (permalink)
MPGuino Supporter
t vago's Avatar
Well, then... I guess I can no longer edit the first post of this thread!
Time to start another workspace thread!
Old 06-16-2017, 11:42 AM   #435 (permalink)
kep
Thanks for your work done, but it does not work with nozzles, peak and hold, I found a sketch. It works, could you add this algorithm to your code?
As well as add voltmert
Excuse me writing serz translator
Old 02-19-2018, 08:30 PM   #436 (permalink)
Hi t vago :
Interesting Project ...Have a shcematic for Arduino Mega ?
Regards !
Pablo.
Old 02-20-2018, 12:30 AM   #437 (permalink)
MPGuino Supporter
t vago's Avatar
There should be some description in the source code on what pins to connect for an Arduino Mega2560.
I have also started using GitHub -> https://github.com/tvago1972/MPGuino
Old 02-20-2018, 06:18 AM   #438 (permalink)
Thank you very match ! :-)
Old 01-17-2020, 09:34 AM   #439 (permalink)
Hi, I created my MPGuino, downloaded the software (different versions) and slightly modified, all right. I want to use it with a marine engine. I also want to use a 20x4 LCD. But I can't edit the code. I see random characters all over the screen. How difficult would it be to edit the code for a 20x4 LCD (HD44780), can you please advise me? I'm getting started with programming. Sorry about my English. Thank you very much. Vítek
Old 03-15-2023, 02:39 PM   #440 (permalink)
EcoModding Beginner
WJ - '03 Jeep Grand Cherokee Laredo
Team E85
90 day: 17.28 mpg (US)
ZJ - '94 Jeep Grand Cherokee Laredo
Alright, I'm a bit lost. I built an mpguino using the legacy schematic with a Nano. I don't have the LCD yet, it comes tomorrow, but it appears to be working. Only thing is I tried to enable serial debugging so I could see some output on the arduino IDE serial monitor, but it never outputs anything. Is there a #define that I''m missing?
