01-12-2017, 05:15 PM
#21 (permalink)
Hi t vago
Thanks for the help calculating, I created a file in excel to help in some calculations, if I can check if everything is working well thank you and can make some corrections if necessary.
The file is here. https://mega.nz/#!hZEDnJpQ!hJ1LKufAT...xUxGz6fUnj2lO4
This last version of MPGuino I am not able to upload the code for the arduino, it starts but then it takes a lot of time and in the end it gives an error but does not specify what it is, maybe it is deep sleep before concluding, because it takes a lot of time for later give the error.
Thanks
José Rodrigues
01-12-2017, 11:37 PM
#22 (permalink)
MPGuino Supporter
iNXS - '10 Opel Zafira 111 Anniversary Suzi - '02 Suzuki Swift GL
Your spreadsheet looks good. I did make a couple of corrections. One was with the labels on your microseconds/gal section, and the other was with your SI correction factor section.
Can you post a screenshot of your Arduino IDE? That would help me in troubleshooting.
I have also included an alpha version of the latest code. I am not sure whether the LCD works, because I am trying to get the deep sleep code working and I need to move the LCD part of the code away from the ADC. I was using ADC for LCD delay generation, and now I am using timer0.
Reason: removed non-production code
The Following User Says Thank You to t vago For This Useful Post:
01-13-2017, 12:33 PM
#23 (permalink)
Hi t vago
Thank you for the correction.
This new version also has the same problem, the compilation is done without errors when it starts to send it is slow and does not send.
This is the information it shows.
Code:
Arduino: 1.8.0 (Windows 10), Placa:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
E:\arduino-1.8.0-windows\arduino-1.8.0\arduino-builder -dump-prefs -logger=machine -hardware E:\arduino-1.8.0-windows\arduino-1.8.0\hardware -tools E:\arduino-1.8.0-windows\arduino-1.8.0\tools-builder -tools E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -built-in-libraries E:\arduino-1.8.0-windows\arduino-1.8.0\libraries -libraries C:\Users\josem\OneDrive\Documentos\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10800 -build-path C:\Users\josem\AppData\Local\Temp\arduino_build_882241 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -verbose C:\Users\josem\Desktop\MPGuino.ino\MPGuino.ino.ino
E:\arduino-1.8.0-windows\arduino-1.8.0\arduino-builder -compile -logger=machine -hardware E:\arduino-1.8.0-windows\arduino-1.8.0\hardware -tools E:\arduino-1.8.0-windows\arduino-1.8.0\tools-builder -tools E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -built-in-libraries E:\arduino-1.8.0-windows\arduino-1.8.0\libraries -libraries C:\Users\josem\OneDrive\Documentos\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=0X2341_0X0042 -ide-version=10800 -build-path C:\Users\josem\AppData\Local\Temp\arduino_build_882241 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.avrdude.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr -verbose C:\Users\josem\Desktop\MPGuino.ino\MPGuino.ino.ino
Using board 'mega' from platform in folder: E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr
Using core 'arduino' from platform in folder: E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr
Detecting libraries used...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\variants\mega" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp" -o "nul"
Generating function prototypes...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\variants\mega" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp" -o "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\preproc\ctags_target_for_gcc_minus_e.cpp"
"E:\arduino-1.8.0-windows\arduino-1.8.0\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\preproc\ctags_target_for_gcc_minus_e.cpp"
A compilar o rascunho...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10800 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\cores\arduino" "-IE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\arduino\avr\variants\mega" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp" -o "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp.o"
Compiling libraries...
Compiling core...
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_pulse.S.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\WInterrupts.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\hooks.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_analog.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_digital.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_pulse.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\wiring_shift.c.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\CDC.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial0.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial1.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial2.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\HardwareSerial3.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\IPAddress.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\PluggableUSB.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\Print.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\Stream.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\Tone.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\USBCore.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\WMath.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\WString.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\abi.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\main.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\new.cpp.o
A usar o ficheiro previamente compilado: C:\Users\josem\AppData\Local\Temp\arduino_build_882241\core\core.a
Linking everything together...
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.elf" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241\sketch\MPGuino.ino.ino.cpp.o" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/core\core.a" "-LC:\Users\josem\AppData\Local\Temp\arduino_build_882241" -lm
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.elf" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.eep"
"E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.elf" "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex"
O rascunho usa 22174 bytes (8%) do espaço de armazenamento do programa. O máximo é 253952 bytes.
Variáveis globais usam 1286 bytes (15%) de memória dinâmica, restando 6906 bytes para variáveis locais. O maximo é 8192 bytes.
E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/bin/avrdude -CE:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/etc/avrdude.conf -v -patmega2560 -cwiring -PCOM4 -b115200 -D -Uflash:w:C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex:i
avrdude: Version 6.3, compiled on Dec 16 2016 at 13:33:19
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "E:\arduino-1.8.0-windows\arduino-1.8.0\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : wiring
Overriding Baud Rate : 115200
AVR Part : ATmega2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 9000 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Wiring
Description : Wiring
Programmer Model: AVRISP
Hardware Version: 15
Firmware Version Master : 2.10
Vtarget : 0.0 V
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9801 (probably m2560)
avrdude: reading input file "C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex"
avrdude: writing flash (22174 bytes):
Writing | #####avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x13
avrdude: stk500v2_paged_write: write command failed
Ocorreu um erro a enviar o rascunho
Thanks
José Rodrigues
01-13-2017, 12:57 PM
#24 (permalink)
MPGuino Supporter
Code:
Yah, my Mega2560 did that a week ago. It would not accept any Arduino program, regardless of what I did. I had to reprogram the bootloader onto it, to make it work again.
I used one of these:
Pololu USB AVR Programmer
to reflash my Mega2560 with its bootloader.
My Mega2560 is my primary test platform, followed by my TinkerKit! LCD module. I was finally able to test the LCD code, and it works... but it is incredibly slow. I am going to revert to using the ADC interrupt for the LCD timing.
01-13-2017, 01:57 PM
#25 (permalink)
Hi t vago
There must be some problem with the code because if I use the version "20170107 - mpguino_1.94_tav.c" it works normally as you can see below, this error only happened in these last two versions.
Code:
Compiling core...
O rascunho usa 19920 bytes (7%) do espaço de armazenamento do programa. O máximo é 253952 bytes.
Variáveis globais usam 1296 bytes (15%) de memória dinâmica, restando 6896 bytes para variáveis locais. O maximo é 8192 bytes.
Using Port : COM4
PAGEL : PD7
BS2 : PA0
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Vtarget : 0.0 V
SCK period : 0.1 us
Reading | ################################################## | 100% 0.03s
avrdude: writing flash (19920 bytes):
Writing | ################################################## | 100% 3.21s
avrdude: 19920 bytes of flash written
avrdude: verifying flash memory against C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex:
avrdude: load data flash data from input file C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex:
avrdude: input file C:\Users\josem\AppData\Local\Temp\arduino_build_882241/MPGuino.ino.ino.hex contains 19920 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.56s
avrdude: verifying ...
avrdude: 19920 bytes of flash verified
avrdude done. Thank you.
Final version of the spreadsheet https://mega.nz/#!ccNBRToC!-hUaaizAv...EDtY_zK2OZ7cFU
Thanks
José Rodrigues
01-13-2017, 02:49 PM
#26 (permalink)
MPGuino Supporter
Hi t vago
Can you tell me (or copy and paste into your reply) what all options you selected? I cannot duplicate your problem, either with the 20170107 version or the version I am currently working on. It might be an issue with your Arduino IDE, as I notice you're using 1.8.0 for Windows. I am using version 1.6.12 for Windows and 1.0.5+dfsg2-4 for Linux.
01-13-2017, 03:22 PM
#27 (permalink)
Hi t vago
I select all the code copy and paste it in the arduino IDE and retreat the commented in #define ArduinoMega2560 true.
I use the portable version 1.8.0 of the arduino IDE, I already tested with the portable version 1.6.0 and it happens the same.
https://www.arduino.cc/download_hand....0-windows.zip
Thanks
José Rodrigues
01-13-2017, 05:40 PM
#28 (permalink)
MPGuino Supporter
Hi t vago
Can you reflash back to the 20170107 version and get it to work again?
01-13-2017, 05:50 PM
#29 (permalink)
Yes without problems, the information I put in the previous post was made after having had the error, and as you can see was done successfully.
I think there is something in the code that disables anything and does not premise communication between the Arduino IDE and the Arduino Mega.
Thanks
José Rodrigues
01-13-2017, 06:50 PM
#30 (permalink)
MPGuino Supporter
I am going to do an experiment here, and edit this post with my results.
https://youtu.be/XLfNDOeNIw4
I can find nothing wrong. I used the most recent version of this code as of this post, and I used the 1.8.0 IDE to upload it to my AtMega 2560.
The code, with the reversion to the fast LCD code, was also successfully tested on my TinkerKit! LCD module.
I honestly can't think of any situation where the Arduino IDE could not upload a sketch it successfully compiled, because of something inside the compiled sketch itself.
Reason: removed old code
