Old 07-09-2014, 02:31 AM   #11 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by Baltothewolf View Post
Read this in another thread, it does seem it will work.
Any '92 - '00 D-series transmission will work (this includes all '92 - '00 civics and Del Sols, except the '99 - '00 Civic Si, and the '94 - '97 Del Sol VTEC)
Lots of people have bolted 1992-1995 trannys onto 1996-00 engines. It is an identical part. I did it 16 months ago on this my daily driver, put a 1993 CX trans on my 1998 DX engine. It really could not be simpler. Look at my chart that Daox linked above. I promise. I checked all details against the factory service manuals and/or multiple other sources. If you can find errors, let me know and I'll edit the tables.
Also guys, I noticed while driving around (about 95F temp outside) that my coolant was between 201-207F, is this normal? Just making sure.
I see those temps sometimes too. My rad fan will come on occasionally in the low 200 range and bring it back down to 194. I have even seen 217 spikes when I cut the engine (and therefore the fan) at the end of a long hard climbs.
Old 07-09-2014, 03:14 AM   #12 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
It never goes below 200F. At least I haven't seen it go that low in the daytime. And thanks, so what are the best trannys I can get? 92-95 CX or 96-00 VX right?
Old 07-09-2014, 03:33 AM   #13 (permalink)
Cyborg ECU
There was no 96-00 VX; you own it's successor, the 96-00 HX. But your gearing is not as tall as the VX's was. The 1992-1995 Vx and the 1992-1995 CX had the exact same gearing. Look for one of those.
Old 07-09-2014, 03:40 AM   #14 (permalink)
Furry Furfag
Ohhhh ok thanks
Old 07-09-2014, 07:50 AM   #15 (permalink)
I did some checking and it looks like, from the information I could glean from the internet, that Honda uses a sensor in the distributor to accomplish what Nissan did with the flywheel ring gear sensor. If that is the case then the transmissions would be interchangeable without 0BD2 issues.
Sorry for the misinformation. Also Calcivic has spent a lot of time on this subject in his pursuit of mileage. I think his knowledge trumps my own being more Honda specific compared to mine which was Nissan speciifc.
Also his post about the shift shaft seal is spot on above and beyond my own.
The part I posted about putting your ear on the shifter to listen for imput shaft bearing noise is still relevant. I used to test for tranny bearing noises by getting the car up to about 30 MPH, turning the engine off with the clutch disengaged and downshifting as the car slowed down, which would make the transmission bearing noises much more obvious. This assumes the tranny is in a functional car, which is not the case with many used transmissions and one should always be aware of "used" transmissions and the reason they were removed in the first place.
Personally I have always felt that the "if it ain't broke, don't "fix" it, as that can, in many cases, turn into much more work than was originally anticipated.
regards
Mech
California98Civic (07-09-2014)
Old 07-09-2014, 09:05 AM   #16 (permalink)
Cyborg ECU
Originally Posted by Old Mechanic View Post
... Personally I have always felt that the "if it ain't broke, don't "fix" it, as the can, in many cases, turn into much more work than was originally anticipated....
Yes! Totally agree. "Test, don't guess" so that you don't "fix" (and waste $$) on what ain't broken.
user removed (07-09-2014)
Old 07-09-2014, 10:47 AM   #17 (permalink)
Furry Furfag
I completely agree with the 'if it ain't broke don't fix it' as I have learned this lesson the very hard way recently... I'm just worried about this tranny leak as I drive 38 miles a day, 8 miles of which is a pretty steep uphill then I have to take a 2 mile stretch of 6% grade, so if it does get low because of the leak, it could leave me stranded and make me lose a day of work, which is an immediate 78$ loss (I only make 9.75 sue me). That's why I need to make sure this is fixed, the proper way before I sell the Corolla.
Old 07-10-2014, 02:41 AM   #18 (permalink)
Furry Furfag
Also, calicivic, if you don't mind, can you compile a list of everything that could be leaking on the tranny? I'm just gonna replace them all at once so another doesn't start leaking in a year.
Also, I have officially gone through 1qt of oil since I bought the car. It doesn't burn oil mind you, it leaks oil. Also I changed the distributor gasket and had a timing belt job done so I'm sure that took like 1/5-1/4 a quart but Yea.
Ok guys, another thing, what all could potentially leak oil on a car? From my very limited knowledge the oil pan, head gasket, oil drain bolt(which is leaking), camshaft, rear main seal, distributor gasket and valve cover gasket right? What else is there?
Old 07-10-2014, 09:21 AM   #19 (permalink)
Cyborg ECU
The list is pretty short:
Input Shaft Seal (tranny must come off).
Driver side drive shaft seal
Passenger side drive shaft seal
Shifter linkage seal
Tranny oil drain plug
Tranny oil fill plug
Oil, of course can flow around the engine parts and the block, however, so be very sure that the leak is coming from the transmission by eliminating other possibilities, other seals, elsewhere on the engine that might leak oil that eventually drips off the bottom of the block or transmission. Distributor seal? Oil filter seal? ...I'm in that process right now.
Old 07-10-2014, 01:48 PM   #20 (permalink)
Furry Furfag
I'm not very confident that my tranny is leaking... I took the fill plug off and it's still full of fluid... And I looked and I can't find a single leak on the entire tranny. The main oil leak is right under the distributor, I already replaced the distributor gasket so it isn't that, it's right under that is where it's leaking..
