08-31-2012, 10:26 AM
#201 (permalink)
EcoMod Proof of Concept
I think all members vehicles should automatically be entered into what ever categories they fit ..
Otherwise its going to come down to dissing lower mpg members to remove their entries because its lowering the TEAM effort ..
Its already happening in the efforts to "convince" members to join other categories ..
The only member anyone should be competing with is YOURSELF
2000 Insight MT 106K Citrus A/C
08-31-2012, 10:43 AM
#202 (permalink)
Coroplast Engineer
I don't think anyone should feel pressured to quit the team. This is a team effort after all, and improvement from any member, whether they're on top of the list or at the bottom, will help the team average.
Originally Posted by Tango Charlie
You know how when you buy a car, and then you start noticing how many others there are on the road? Yeah, that doesn't happen with a 1st gen Insight.
AV Build Thread
The Following 2 Users Say Thank You to slowbro For This Useful Post:
08-31-2012, 11:38 AM
#203 (permalink)
OCD Master EcoModder
I agree. All members are valued, and each member's score figures equally in the team's numbers.
Apparently a car can be a member of more than one team. So joining the boat tail or sports car team wouldn't remove a car from Team Honda.
Coast long and prosper.
08-31-2012, 01:38 PM
#204 (permalink)
Originally Posted by California98Civic
The more the merrier!
Sounds good. Don't worry too much about team average. We like to bring it up, but it is really about encouraging high FE efforts. The more the merrier!
Thanks for the warm welcome!
I'm still calibrating my Ultragauge, so it was a little optimistic this tank, but still got 46.9mpg.
08-31-2012, 01:53 PM
#205 (permalink)
Each fill is better than the previous one - nice!
09-01-2012, 07:00 AM
#206 (permalink)
Congrats are in order:
In addition to darcane's improving results noted a few posts above, RoadtripChris and Ecky both had best-ever mpg's in August, and an overall increasing mpg trend.
Good going!
09-01-2012, 07:11 AM
#207 (permalink)
MPG Militia HMV-25E80+A
Not right now. I've been trying to do multiple teams for a while and it doesn't work for me anyway.
09-01-2012, 09:05 AM
#208 (permalink)
True. I just recently pm'd MetroMPG to as if he would make that change.
09-02-2012, 02:04 PM
#209 (permalink)
Red Light Avoider
Finally got 2 amp battery charger installed in the car. I also tracked down the block heater cord for when things finally get back to normal around here. Still 30C today in September! I'll have to plan out the wiring, thinking about joining the charger and block heater lines under hood with a simple 3 into 1 fitting, then wiring up a marinco flush plug to mount on the bumper or some other handy place. That way it's all aero when underway. Seen a truck forum with this setup. Looks very cool.
I also did an oil change and switched to synthetic (well, I don't really know what was in there to begin with...). Note to self: changing oil outside on the windy day not such a good idea...
Next up is thought into grille cover! What are you guys using?
09-02-2012, 04:43 PM
#210 (permalink)
Have a look here
http://ecomodder.com/forum/showthrea...nel-22503.html
I read that our generation Civic has a drain plug on underside of block. I think to the passenger side of the oil pan? Worth taking a look, instead of wrestling with a freeze plug. I think they are hard to reach between the exhaust connections. Again, based on reading; not on looking.
The Following User Says Thank You to brucepick For This Useful Post:
