Old 05-20-2011, 03:04 PM   #1 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Tested rpm-mpg
I ran a test for baseline and did it 3 times to verify.
57 mph on cruise on a 10 mile stretch with a couple decent climbs/descents.
6th gear= 2000 rpm and 49 mpg
5th gear= 2490 rpm and 44.5 mpg
4th gear= 3000 rpm and 39 mpg
Seems to show that less rpm is certainly better. I have room to go up on tire height but 27.5"-28" OD would be maximum. Current tires are 25.5" OD so around a 10% reduction in tire rpm will net how many less rpm's?
Old 05-20-2011, 03:37 PM   #2 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
This shows the potential mileage that the manufacturers of all of those high cruising RPM MT cars are leaving on the table that could be attained via an inexpensive gear ratio change. Those 40mpg MT Fits and Yarisis could easily be 50mpg cars running in Prius and Civic hybrid mpg territory if they were geared properly for highway cruising and their engines would also last longer.
The Following 2 Users Say Thank You to basjoos For This Useful Post:
landsailor (05-21-2011), PaleMelanesian (05-23-2011)
Old 05-20-2011, 03:37 PM   #3 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
10%
Old 05-20-2011, 04:47 PM   #4 (permalink)
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
When you change tire diameter, any vehicle specific MPG meters will be off as will the speedometer. You'll need to recalibrate or use a correction factor, 10%, to be able to compare with your baseline.
LATE THOUGHT: Rather than buying four new tires, buy one and a full-size rim. Then put it on a front and later rear wheel to test for interference. It is a lot easier to 'eat' the cost of one tire than four.
You can also get just a second tire and then put them on the drive wheels. Often this is enough to test your hypothesis about revs/mile and vehicle efficiency without having to put so much money into tires.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
Old 05-20-2011, 06:36 PM   #5 (permalink)
My odo is 2.8% low compared to my GPS anyway so recalibration would not be a problem.
10% would be a start as it shows every little bit helps.
Old 05-20-2011, 10:43 PM   #6 (permalink)
Yeah, a lot of MPG is left on the table in the Honda manuals. I would love to know what my Element could do at, say 2300 rpm vs 3500 rpm when cruising...
Old 05-21-2011, 02:56 AM   #7 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
is it a 4 or V6?
It will probably drop your rpms to 17-1800. Which could be a sweet spot for a 6. I don;t about the 4 bangers.
But given the potential drop in rpm, It would be worth it.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 05-22-2011, 12:50 AM   #8 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Originally Posted by mcrews View Post
is it a 4 or V6?
The v6 Sonata is gone as of the '11 model, replaced by the turbo 4.
But we also have the Garage for that sort of question .BHarvey's '11 Sonata
The CR-Z runs 2400-2500RPM at 60mph and it's only a 1.5L in a 2600lb car. Some of those guys are getting 40's to 50mpg tanks
Most manual 4 bangers run high 2000's to 3000RPM at 60mph. That leaves a lot of room for improvement and people are going complain to complain either way about these cars being underpowered .
-Allch Chcar
Old 05-22-2011, 08:02 AM   #9 (permalink)
Laura the Lancer - '81 Mitsibishi lancer LX
my 29 year old car at 60mph (97ish kph) turns 4300rpm
and i still get high mpg's imagine wgat i would do if it had the power to turn lower rpm
cant wait till i put my fuel injection setup on, it'l be nice to get some waaay higher mpgs
Old 05-22-2011, 04:44 PM   #10 (permalink)
I don't know why people complain about power, it will spin it up in first gear and start to in second, and this is with TC on!
