Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 02-09-2020, 06:17 PM   #91 (permalink)
To legally ride an e-bike in NYS it must be purchased from an approved manufacturer and registered as either a Class B (30 mph) or Class C (20 mph) scooter. You need a driver's license to operate a Class B vehicle. To learn if a scooter is approved one must call the Tech Center in Albany. A Class A scooter is a motorcycle and one can get a VIN for a home built custom bike that meets inspection. Lime e-bikes are available for rent.
Old 02-10-2020, 12:24 PM   #92 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
I'd like to see an unlimited bike race where you can do anything as long as it's 100% human powered. The basic bike shape hasn't changed since 1885. We might see some trickledown innovation if there were an unlimited class.
[/IMG]
Look up Human powered vehicle competition. It's an ASME event.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 02-11-2020, 05:06 PM   #93 (permalink)
ASME is run for college students usually.
Old 05-23-2020, 12:10 PM   #94 (permalink)
Lord Vader - '15 BMW i3 REx
90 day: 35.06 mpg (US)
Re: e-unis: I think there would be too much bleeding.
But how much is "too much" if it is fun?!?
Confession: I crashed on mine at 10mph and cracked a wrist, nearly amputated the tip of my index finger, and removed about 0.10 square feet of skin from my elbow because like a dummy, no pads. My EUC does not go more than about 13 mph, but I gear up for anything more than a walking pace now.
2015 BMW i3 REx
2011 Ford Flex SEL AWD
The Following User Says Thank You to Snax For This Useful Post:
redpoint5 (05-24-2020)
Old 05-23-2020, 03:48 PM   #95 (permalink)
When I noticed someone had poked the thread, I started with the title: Thoughts on using electric unicycles? My thought immediately went to a clip of a Onewheel on a hiking trail, with a headlight in front of your lead[ing]foot.
NYC is using the presence of a throttle on the bike as the deciding factor.
So, Segway and Onewheel good to go?
"We're deeply sorry." -- Pfizer
Old 05-24-2020, 11:55 AM   #96 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
I lent my Segway out to a friend of a friend and they crashed it into a rock. I'll probably figure out how to fix it, but makes me more serious about getting a dangerous uni. I'm thinking 35 MPH is the minimum I want to look at. Still don't know why these things are going for over $1,000.
Old 05-25-2020, 09:15 AM   #97 (permalink)
IamIan's Avatar
I've been using an electric unicycle for about ~1year now.
It took me about 8-10 hours of regularly falling , or stepping off to get the basics down .. kind of like walking you fall allot at first , or learning to ski , etc.
When I contacted RI DMV they told me :
(your state may vary)
When clearly bicycle.
When the non-human power (combustion or electric) provides under 1.5hp and not above 20MPH .. it's the same as a bicycle .. Can use on bike paths , bike lanes , etc .. no registration required , no license required.
When Grey area could be a scooter.
When non-human power is over 1.5HP but under 4.9 HP .. or .. that non-human power goes over 20MPH but under 30MPH .. then it could be considered/classified as a scooter .. if a scooter .. no license required .. registration would be required .. and could not use bicyle path or bike lanes .. however code does not yet include unicycles specifically .. so it can not be registered at this time .. and weather such would or would not be a scooter is still undermined.
Clear when could be a motorcycle.
when non-human power is over 4.9HP .. and/or .. non-human power over 30MPH .. then it would be considered a motorcycle .. license required .. registration required.
I don't know what police officer would choose to enforce that .. but .. they could ticket for anything I guess .. and then if you challenge the ticket .. then the court can rule one way or the other .. sometimes a ticket get's tossed by the court , sometimes they don't.
The model I got is a Solo Wheel Glide 3 .. I'm told it's hardware is the same as the Inmotion V8 (just a few software tweaks).
OEM:
This model is a ~800watt motor .. soo .. under the 1.5HP limit.
This model is limited to 18~19MPH .. soo .. under the 20MPH limit.
This one gives me 15-20 mile range per charge .. YMMV.
soo in RI .. OEM .. this one is treated as a bicycle , for where I can go , and not needing registration or a license .. even if I'm stopped , I should still be fine.
I also personally like the near bicycle power/speed .. if I want to go 40+ mph I will just get in my car.
When cargo is no more than 1 back pack worth .. it's a good fit.
Over the year I've had mine .. as I build up more condition / endurance .. I see that I might eventually like to have more range .. 15-20 miles is enough for short trips to grocery store and such .. very long range of the higher end models ~80 miles or so really starts to show the massive energy density advantage human fat has over modern Li batteries , as the weight of those wheels goes up considerably.
This model is not one of the ones with built in suspension .. some people have done that after market .. and some of the latest models have that option OEM .. so , my slightly bent legs and the give of the tire are all I have .. so mine is best for fairly good surfaces .. the worse the surface or faster the speed the more valuable suspension will be.
I have had ebike's for years .. so why go to a EUC ?
It provides roughly the same (as bicycle / ebike) extremely high energy efficiency .. YMMV .. I see 30-40 Miles per kwh .. in some cases it will be more energy efficient per mile than walking.
It is much smaller volume to transport and store (even than my previous folding ebike) .. this makes it easier to transport in my small car to a bike trail , or take on vacation .. or .. to put in car , and use as my ride home , when my car needs to be dropped off at mechanic .. or .. space store at home when not in use .. etc.
As it is smaller than some rolling pieces of luggage .. I have had no problems walking it in with me on small shopping trips (groceries and such limited to back pack and carried in hands) .. where my ebike would have to be left locked up outside.
Used in the self powered rolling luggage mode .. it still has it's carrying capacity .. on mine that's only ~250lbs .. but there are other models up in the 300-350 lbs capacity range .. in this mode it can act as an electric mule .. and can carry that ~250Lbs for me .. which can sometimes be nice .. and some some of those small trips with back pack full I've been over the ~250lbs .. so a higher carrying capacity might also be something I see as being nice eventually.
For amount of physical effort / exercise :
Casual walking:
Standing EUC is more effort / exercise.
Sitting EUC nearly the same .. but using different muscles.
Jogging / running:
EUC stand or sit is less effort / exercise.
Bicycling Down hill:
EUC stand or sit is more effort / exercise.
Bicycle Flat level cruising:
Standing .. EUC is a little less overall .. but a different muscle group .. bicycling mechanically applies the human effort better .. large muscle groups / leverage / etc .. standing on EUC is feel it in those smaller areas like feet and such.
Sitting .. EUC is much less effort / exercise.
Bicycle up-hill and/or higher racing speeds.
EUC stand or sit .. less effort / exercise.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following 2 Users Say Thank You to IamIan For This Useful Post:
Grant-53 (06-02-2020), redpoint5 (05-25-2020)
Old 11-25-2020, 11:32 PM   #98 (permalink)
My Segway mini is back in business after a $40 part from China. I paid a Russian hacker for a firmware that allows it to travel 16 MPH (up from 10) and about tripled the power available to go uphill. Huge difference in usability/enjoyment now. I've got 300 miles on it now.
I recently bought a hoverboard for $65 and they are pretty lame compared to my $350 Segway mini. Got it with my 2 year old daughter in mind who wouldn't be able to physically fit on my Segway until she's probably 7. Maybe she'll master the hoverboard by age 3 and we can cruise together.
Would still love to pick up one of those monster EUCs. I'll keep checking Craigslist for a deal.
On a longer time horizon, I'm waiting for a Chinese knockoff of this;
The suit, which creates 317 pounds of thrust and makes 1,050 brake horsepower, carries 5.25 gallons of jet fuel. That will allow it to propel a person of less than 200 pounds for about four minutes
Old 11-26-2020, 03:40 PM   #99 (permalink)
I've actually been contemplating selling my One E+ over safety factors. I don't really see them as particularly dangerous with the right gear and sane riding, but I am 51 and a widowed father with kids to take care of. Same reason I don't have a motorcycle either.
I scarcely rode mine this last year at all. It has been super convenient for doing things like dropping off or picking up a car at the mechanic, but Uber works too.
2015 BMW i3 REx
Old 02-18-2021, 05:49 PM   #100 (permalink)
IamIan very graciously re-homed his EUC with me.
The first time I attempted to stand on it, it seemed impossibly difficult. I just stood wobbly in my garage hanging onto things for support. It waived back and forth against my ankles which I was gripping the EUC with, causing some bruising there and on my shins.
About 2 hours of actual time spent on the EUC, I was finally making very sketchy turns. I'd ride white knuckled wearing a bike helmet and gloves.
Now I've got about 50 miles of riding in and it's becoming 2nd nature. Very slow speeds is challenging, but otherwise I'm very comfortable with it. It's even more stable going downhill than the Segway is because it doesn't introduce a positive feedback oscillation when braking.
I took this footage while riding the EUC IamIan gave me. It really is the superior way to travel, and I have practically no interest in 2-wheeled personal electric vehicles anymore.
https://drive.google.com/file/d/1axh...ew?usp=sharing
https://drive.google.com/file/d/1f72...ew?usp=sharing
Thank you Ian! Most fun toy I've got by far.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
freebeard (02-18-2021), IamIan (02-18-2021)
