Old 07-22-2012, 07:36 PM   #1 (permalink)
TBD - '17 Toyota Corolla LE
90 day: 40.79 mpg (US)
Starship - '08 Toyota Prius
90 day: 42.34 mpg (US)
Thoughts on wheel covers...
What's the consensus, is it the reduction of the volume of air that passes through them that is cut off/reduced (i.e., closing up the spokes and sealing them), or that they are flat (which does the same of course, but with the added benefit that they are flush to the tire) that is responsible for the drag the reduction?
I'm contemplating modifying my existing hubcaps by simply filling in the "spokes" and insuring no gaps between the hubcap and the tire, but this won't make them flush.
Old 07-22-2012, 11:32 PM   #2 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Trial it with duct tape, it will give you a ballpark of what you can expect, but minimal cost and time
invested.
Some cars have better results than others with respect to wheel covers.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 07-24-2012, 11:53 AM   #3 (permalink)
invested.
Taped up the spokes, we'll see how it goes across this tank...report in a week.
Old 07-24-2012, 05:05 PM   #4 (permalink)
Mostly closed is good, and flat and closed is better.
Old 07-24-2012, 06:12 PM   #5 (permalink)
consensus
I've yet to read a complete discussion on wheel covers.
Observations have been reported and recommendations.
*An open wheel has no surface with which to 'support' airflow,so a solid surface is needed.
*A slightly convex disc won't 'tin-can',is extremely rigid for it's mass,and has a measurable drag advantage over a flat disc.
*Brake cooling should not be ignored,however solid 'MOON' style wheels have shown to be no disadvantage for many members including myself.
*The knock-on style covers are noisy and eventually come off.I've written them off.
* I was able to scrounge up a set of covers from a 1975 Buick Electra.They are absolutely 'silent,' securely hold to the wheel,and have modest ventilation for brake cooling.
*Many members have found covers which stay firmly attached which can be modified aerodynamically.
Old 07-27-2012, 06:57 PM   #6 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Flat coroplast circles zip tied around the spokes work well.
MetroMPG probably has an ABA test on wheel covers somewhere. I'm not sure of the % improvement but wouldn't expect more than 1mpg.
Old 07-27-2012, 08:29 PM   #7 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
wiki link to wheel covers and data:
Smooth wheel covers - EcoModder
5 users did aba testing and got 1-1.5 gain or 2.4%-4.6% gain. not to shabby for an easy cheep mod
The Following 2 Users Say Thank You to Weather Spotter For This Useful Post:
Sven7 (07-29-2012), woodstock74 (07-27-2012)
Old 07-30-2012, 05:23 PM   #8 (permalink)
Well first tank down...big gain. Saw highest MPG yet, 35.88.
I simply taped over the spokes as the test. I'm working on a permanent solution:
Old 07-30-2012, 05:33 PM   #9 (permalink)
Wiki Mod
looks like a good start, what were you running before this tank?
Old 07-30-2012, 06:13 PM   #10 (permalink)
The 16 week average prior was 33.59.
