Old 05-27-2011, 02:48 AM   #11 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Oooo, that Opel also seems to have small spats in front of the rear tires.
Old 05-27-2011, 04:05 AM   #12 (permalink)
Those look like they're made to deflect air so it doesn't hit the suspension components.
Old 05-27-2011, 05:27 AM   #13 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
one thing i think to keep in mind when looking at these things is that the dams in themselves are very unaerodynamic shapes, so they will generate a rather wide "wake",
i suppose they don't need to be the full width of the tire to send the air cleanly around it
so when reverse engineering it's best not to assume "bigger is better"
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
The Following User Says Thank You to lunarhighway For This Useful Post:
aerohead (08-31-2019)
Old 05-27-2011, 09:11 AM   #14 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That's part of what I did with my DIY spats too. I have been meaning to test them.
Old 05-27-2011, 09:13 AM   #15 (permalink)
Moostange - '07 Ford Mustang GT
Last 3: 21.8 mpg (US)
Originally Posted by piers.singer View Post
It's interesting to note how small the OEM deflectors are compared to some of the DIY jobs on here (if you've acres of coroplast then you might as well use it), maybe the manufacturers are saving material/cost or maybe they don't want the aero parts to impact on the car's styling.
They are also looking at the simplest installation possible.
The larger flaps are also somewhat flexible; they will bend with airflow. I remember the early Ford Contours had flaps in front of the wheels. At the time I had no idea what they were there for.
Old 05-27-2011, 09:24 AM   #16 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
In the week I spent driving a Fiesta, that air dam scraped on at least a dozen driveway/lot entrances. It's a little on the "too low" side.
Old 05-27-2011, 09:29 AM   #17 (permalink)
Hypermiler
Wagons
Autospeed - Modifying Under-Car Airflow, Part 2
The Following 2 Users Say Thank You to PaleMelanesian For This Useful Post:
California98Civic (10-16-2011), TimRogers (04-16-2021)
Old 05-27-2011, 03:09 PM   #18 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
About half of the cars I looked at had rear tire spats as well. Pretty much all the same back there. Small, flat and straight. Here's the Honda CRZ rear spat:
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 08-31-2019, 02:46 AM   #19 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I have been doing testing on these flaps a lot lately and they do effect the consumption a lot.
I took 10mm off from each flap after this video and consumption got back to 0,1liter higher to 5,5 liters.
Flap width is usually narrower than the tire. Do notice that inner side is wide because it also directs air away from the suspension lower a arms etc. just 10mm changes to shape and size can have measurable impacts.
Tip is that build adjustable flaps in heigth first and get the heigth best setup After that build flaps that you can adjust the width also.
Optimum heigth of the sparts are aroung 40-70mm. And width needs to be about 40mm.
Conserning the A arms the best heigth is around the lowest point af the nearest body structures behind the flaps. Usually lowest point of the body.
You have to be able to test these mods in calm conditions as wind do effect fuel consumption of the results close to 10% and easily 5%. So best is that you try to find level road for 3-5km and test the consumption to both directions. make fast changes and repeat the test. Try to keep measuring speed high so its easier to see the differences. I test usually at 100 km/h, but I will try the method I described and will test at 120 km/h to see better results. To get the smaller differences. I also keep records of the consumption at various points on my test route to see if the consumption changes earlier or later compared to previous setup. That is because in Finland near me is not perfecly level roads so there is up and downhills on the route.
I will also try to test to put angled flap when I have found the best setup if that brings even more gains.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 2 Users Say Thank You to Vekke For This Useful Post:
Gasoline Fumes (08-31-2019), MeteorGray (08-31-2019)
Old 08-31-2019, 05:57 AM   #20 (permalink)
teoman's Avatar
A3 - '12 Audi A3
I wonder if the angle has any influence?
Also if they produce some noise one could put a small sawtooth profile on the end.
