Old 10-12-2009, 08:03 PM   This thread is in the EcoModder Project Library | #1 (permalink)
Torontocity's Avatar
Toronto Greetings (1994 Suburban w/ Mercedes diesel swap)
Hey all...I'm a family man...Seven kids...need a big 4x4 truck, y'know Toronto and snow...Well i got a 94 Suburban but tired of going gas station to gas station...so i'm Pulling out the gas engine and installing a mercedes benz 5 Cyl. Diesel. I know...you'll say not enough power...But i'm adding a 700r4 Transmission and i promise not to go wall climbing.
I am in the prosess...engine and tranny is out and Diesel engine is in Machine shop making an adaptor plate...Now i am less that a novice and i'm gonner need all the help i can get...Mostly with wiring.
Will keep y'all up to date...
Old 10-12-2009, 08:25 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
The newer Mercedes 5 cylinder diesel installed in the Dodge Sprinter van is a surprisingly powerful engine. Is that the engine we are using?
GeoMetroforum.com - got mpg?
Old 10-12-2009, 09:14 PM   #3 (permalink)
I Wish!!! This is a 1984 W126 diesel...pretty good on the Car...We'll see how she performs on the Truck...
Old 11-01-2009, 07:34 PM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Belated welcome, Torontocity.
And... sounds like a really interesting project. You won't find me accusing anyone of having an underpowered engine! I'm of the opinion that my 49ish horsepower is excessive. I'd gladly trade some of it for more efficiency.
I hope you'll keep us updated. Please start a dedicated thread and we'll put it in the Project Library.
PS - I spent my first 15 years in Scarberia.
Old 11-19-2009, 08:01 PM   #5 (permalink)
UPDATE !!! The truck is up and running... Copy and paste this...
Old 11-20-2009, 08:10 AM   #6 (permalink)
Congratulations, Torontocity - is that the engine you had planned to use in your intro post?
Looking forward to your driving impressions & fuel economy reports.
Old 11-20-2009, 05:32 PM   #7 (permalink)
Well...i had the choice between the Turbo 300SD and non Turbo 300D...I went with the Turbo...It Pulls Good...........
Old 11-20-2009, 09:50 PM   #8 (permalink)
Turbo Lurker
moTthediesel's Avatar
VonBondo - '65 Porsche 356SC Coupe
Cool!
I used to have an old LandCruiser FJ60. I pulled out the straight six gasser and put in a Canadian market Toyo 3B four cylinder diesel. I added a turbo that I got on fleaBay and it ran great. If anything it accelerated faster with the new engine, and it improved my FE from 14 mpg to 25 mpg --Great Success!
Good luck with your project -- and it sounds great -- like a real truck!
Old 11-21-2009, 12:27 PM   #9 (permalink)
Should really have tried to keep one thread going on this topic...
Anyway, here's the other thread discussing this project:
http://ecomodder.com/forum/showthrea...hed-11067.html
Old 11-24-2009, 02:59 AM   #10 (permalink)
the OM617, the one with turbo makes 150hp @ nearly 5k! kkk makes a k26 turbo which is next size larger direct bolt on with integrated wastegate. the factory turbo was a bit too small therefore the high rpms required to make any power.
if you ever do any work on it port the head and look for an intake manifold off
another benz i can look up if you are interested.
intercool and consider water injection to manage your egts now that you are dragging around another 2-4k Lbs with 2x the CD to boot.
once you get it tuned you can expect some interesting MPG!
the 700t is it 4 or 5 speed, you made the adapter from scratch?
what did you do for a flywheel/clutch? do you have any pictures?
i have been wanting to do this to a early 70's f-350....
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
1995 Civic or 1984 Mercedes 190 Diesel ?? Hip001 General Efficiency Discussion 17 10-05-2010 12:38 PM
Mercedes diesel non electronic oldbeaver Instrumentation 8 03-04-2010 02:32 AM
Canceling out pumping losses of throttle governed engines greasemonkee EcoModding Central 60 08-03-2009 04:24 PM
As I Had Thought Big Dave General Efficiency Discussion 54 09-02-2008 11:00 PM
