Old 11-22-2012, 10:42 AM   #101 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Darin,
I was reading the earlier comments in this thread and got the part where you discussing what gears to use to achieve about 1200 rpm at 55 mph, if I recall correctly.
So I used one of the ScanGauge channels to show rpm, and in the Insight this turns out to be 1200 rpm at 35 mph.
Now in the summer, this creates a very easy load for the engine, but in winter driving it is close to the bottom rpm I can run without the engine "throbbing" from the 3 cylinder engine pulses.
I guess I am wondering out loud if you could actually drive the car with a wind load at 55 mph and still maintain this engine rpm?
Seems pretty low to me.
Jim.
Old 11-22-2012, 11:42 AM   #102 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
It is low, and to be honest, I was probably just thinking out loud when I posted that.
This thread has turned into a bit of a monster and the unfortunate thing is: while I did actually start on having a custom set of gears made, I never finished the project.
Proceeding further isn't on the radar since the Firefly was relegated to "backup vehicle" status after I got the Insight. It's not even on the back burner... it's right off the stove!
Christ (11-23-2012)
Old 02-19-2020, 08:25 PM   #103 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
What ended up happening with this project (like current status of the parts that you ended up with)?
I'm looking into attempting this because I've actually got a wire EDM at work as well as we do some heat treating. We also have induction machines (is that the proper name?) that I might be able to use to heat treat the teeth atleast.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 02-20-2020, 05:56 AM   #104 (permalink)
2020 - '08 Chevy Tahoe H
Last 3: 18.4 mpg (US)
2021 - '08 Chevy Tahoe H
90 day: 17.08 mpg (US)
2022 - '08 chevy Tahoe LT
Last 3: 14.38 mpg (US)
2023 - '08 Chevy Tahoe
90 day: 25.57 mpg (US)
Originally Posted by 3-Wheeler View Post
Darin,
Jim.
got you beat 1000rpm at 35-42mph
85mph =1800rpm 4 banger mode
with low end power it's a non issue is your insight VVT? you could gain some low end power using higher octane fuel you will also gain some MPG as they use summer gas for the higher octane
Old 02-20-2020, 09:53 AM   #105 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
As like many others Geo Metros are wearing out or rusting away. I have moved on to a Saturn L and am happy with the change. I played with Metros for 8 years and most Metro people are Mitsubishi Mirage owners now. The quest for mileage continues.....
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 02-20-2020, 10:27 AM   #106 (permalink)
Project Status: abandoned!
The only step I actually had done was having the teeth machined off one of the gears.
This is one of those things that was going to cost a lot more than I could justify.
Also, if it isn't done perfectly, metal contamination of the trans oil could ruin the rest of the gearbox (gear failure happened to another car I know about which did this mod).
Old 02-20-2020, 12:29 PM   #107 (permalink)
マット
M_a_t_t's Avatar
Team Chevy
Motorcycle
Team Ford
Alright.
Atleast the curiosity has been satisfied. Thanks
1995 Mercury Tracer
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 11:08 AM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Another Metro to get taller final drive & XFi cam Frederick EcoModding Central 19 01-26-2012 12:32 PM
Met an unhappy Aveo owner today MetroMPG General Efficiency Discussion 24 10-10-2010 07:03 AM
Home made hybrid (using access to 5th gear on FWD transaxle) AXMonster Hybrids 17 10-19-2008 05:35 AM
