Old 07-12-2011, 02:54 AM   #11 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
Currently experimenting with some minor aerodynamic mods.
I also intend to change the stock exhaust manifold with a 4-2-1 header and perhaps a lightweight crank pulley.
They should provide a noticeable increase in low-to-midrange torque, which is likely to increase fuel efficiency. Thinking about switching to synthetic oil to lower internal friction, but that remains to be seen.
Check out this thread concerning my current aerodynamic mods :
http://ecomodder.com/forum/showthrea...cho-15673.html
Cheers !
The Following User Says Thank You to CigaR007 For This Useful Post:
HyperMileQC (12-02-2011)
Old 07-12-2011, 09:43 AM   #12 (permalink)
I have been using synthetic oil since I bought the car, but I am switching to synthetic 0-20
Old 07-12-2011, 11:56 AM   #13 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I managed a 1033 km tank with my boxy Scion xB, which shares the same 1NZ-FE engine and 11.5 gallon gas tank used in the Echo. I'm handicapped with shorter gearing, larger frontal area, and brick-on-wheels aerodynamics, so you MT Echo owners can certainly match and surpass my accomplishments.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
alainmci (07-12-2011)
Old 07-12-2011, 01:58 PM   #14 (permalink)
CigaR007's Avatar
Did you use P&G and EOC techniques? I simply refuse to turn off my engine while coasting, for safety reasons and I do not like the tedious work P&G requires.
Old 07-12-2011, 02:56 PM   #15 (permalink)
Pishtaco
SentraSE-R's Avatar
Yes, I do. But I've ridden with an MT Echo owner who managed to average 60+ mpg over a 10 mile loop (matching my xB's P&G/EOC mpg while he rode in mine). He did it simply driving with load.
Darrell
Old 07-12-2011, 03:30 PM   #16 (permalink)
CigaR007's Avatar
I did average 62.6 MPG over a 30-mile commute once (DWL), but it was perfect conditions and I haven't been able to replicate that result.
Old 12-02-2011, 01:54 AM   #17 (permalink)
Hi All,
I am new here and looking to get a set of tires for my 01 Echo. I am having trouble deciding on whether or not I should go from a 14" to a 15" wheel or not. I am looking for better fuel efficiency and also improved handling. I do not know if going to wider 15" wheel will net me improved handling. I might just go with a 14" LRR tire. Looking for suggestions and looking forward in joining this forum!
Old 12-02-2011, 02:04 PM   #18 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
Good to know that another Echo is joining the Ecomodder community. If you want some inspiration or details on how to eco-mod and echo, you can visit :
Echo-Troll Modding Thread
I hope that you realize your goal, I think it is completely doable. Good luck for the rest!
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Has anyone converted/modified a 2003 toyota echo? trdfreak03 Hybrids 7 06-11-2012 03:09 PM
Aerodynamic Belly Pan on Toyota Echo jime57 Aerodynamics 23 12-05-2010 07:18 PM
ScanGauge II speaker mount for 2001 Toyota Echo alohaspirit DIY / How-to 7 02-06-2010 06:29 AM
Engine off switch in a Toyota Echo johnnymac EcoModding Central 1 12-24-2009 04:41 PM
Toyota Echo power steering delete mod? zman EcoModding Central 29 05-17-2009 09:36 PM
