Old 10-25-2019, 02:22 PM   #1 (permalink)
Environmentalist
Galvatron1's Avatar
Toyota MPG Chart in a non-modified 2014 Camry SE
Just out of curiosity, what's the best mpg an unmodified non-hybrid Camry can get of this generation? I think the absolute best I can get is 60-80+ Mpg on highways for a minute or 2, since the chart doesn't read above 60 mpg. The worst I can get is in city traffic with lots of stop & go traffic, poor traffic light sequences & heavy congestion yields sub 5 MPG. Avg overall is mid 20s mpg.
Not sure what I can do to net gains. I inflate my tires 1-2 psi above the door jam 35 PSI recommendation. Sidewall max PSI is 51. I hope to not induce premature tire wear by exceeding the manufacturers PSI rating. .
How accurate is the Toyota MPG screen?
Old 10-26-2019, 09:37 AM   #2 (permalink)
90 day: 40.51 mpg (US)
I'm not aware of anyone else on this site with a Camry from those years. Manual or automatic? You might find what you're looking for in this thread:
https://ecomodder.com/forum/showthre...you-15182.html
Most vehicle fuel economy gauges tend to be quite optimistic. I drive a Ford Transit Connect for work and find the gauge can be as much as 20% high. In other American vehicles I've driven, the fuel economy computer stops counting when you're in neutral or at a stop. My Insight's computer on the other hand tends to be within 1% accuracy, possibly more accurate than fuel pumps.
I found that my tires wear most evenly at 44-48PSI. At the factory recommendation of 38, the edges tend to wear first. A few people on Insight Central run over 60 PSI, with one that I'm aware of running 120 in his tires with no reported issues so far. Not that I'm recommending it.
I wish I could speak more specifically for your car.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
Galvatron1 (10-26-2019), Xist (01-29-2020)
Old 10-26-2019, 10:31 AM   #3 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
While OE gauges are not usually accurate, many have several modes, some may be more accurate than others. These mode may include tank average , instantaneous and on some cars the average for the last 15 minutes. Check your manual for specific information on you vehicle. If it didn't come with one the Toyota web site offers a downloadable PDF version.
Link to tracking fuel mileage.
https://ecomodder.com/blog/hypermili...l-consumption/
The Following User Says Thank You to nemo For This Useful Post:
Old 10-26-2019, 02:27 PM   #4 (permalink)
Environmentalist
Galvatron1's Avatar
It's automatic transmission. No other same Gen Camry drivers on this forum?
My mpg screen shows avg mpg per minute for the last 15 minutes. It fluctuates in the current minute's mpg bar, based on how hard the throttle is depressed.
Really could use a suggestion of how high on psi for tire pressure I should run for max fuel efficiency without wearing out the tires.
Old 10-26-2019, 03:00 PM   #5 (permalink)
nemo's Avatar
If you do a search in the garage it looks like only 2 Camry drivers are updating fuel logs.
My starting point for tire pressure is 4 PSI above recommended (cold), this is based on a general experience that I wear the inner and outer edges. Many here run much higher. Do a search here, many discussions of tire pressure and wear.
Galvatron1 (10-27-2019)
Old 10-26-2019, 10:37 PM   #6 (permalink)
Little Blue Fuel Sipper - '16 Nissan Versa SV Sedan
90 day: 45.75 mpg (US)
The factory gauge in my Nissan Versa is usually between 5 and 10% optimistic.
The Following User Says Thank You to 2016 Versa For This Useful Post:
Old 10-27-2019, 06:56 AM   #7 (permalink)
Joggernot's Avatar
I tried to keep track for a 2018 Honda CRV. Average is 1.7 mpg higher than calculated for the first 20k miles.
Old 10-30-2019, 09:39 PM   #8 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
You know you can just go to the Garage page and specify it list only Camries, right? Takes about ten seconds. Even if there aren't many currently being updated there are quite a few to look at, including a few with some depth of coverage.
The highest scoring Camry in the Garage is a '99 four-cylinder at 39.84 MPG average over 60k miles. I can see your car scoring short term moving averages touching 60mpg, but not over a whole tank.
You say you're facing a lot of stop and go, your biggest improvement will come from weight reduction.
The Following User Says Thank You to elhigh For This Useful Post:
Galvatron1 (10-31-2019)
Old 10-31-2019, 10:43 AM   #9 (permalink)
Environmentalist
Galvatron1's Avatar
I'll try checking out the Camry garage, thanks for the suggestion. Yesterday I inflated my tires to 40 psi, from 35 psi.
The car is usually empty, I don't carry a whole lot in the car. But you're totally right a weight reduction would show a significant improvement in mpg.
You are exactly right about touching 60 miles per gallon for a minute or two! On the highway I can seldom get over 40 miles per gallon for 15 minutes in a row. .
Old 10-31-2019, 11:08 AM   #10 (permalink)
Environmentalist
Galvatron1's Avatar
I think I read a tip about not running your heat until the car is at operating temperature , Because it's more efficient.
Although some say it's not necessary to warm up your car when you're first getting started. What are your thoughts on that? From an efficiency standpoint, is it better to warm up your car for a minute or two? Or until it drops under a certain RPM's?
