Old 07-10-2014, 01:01 AM   #1 (permalink)
wreck front - '98 honda civic hx
Tps lod not always constant
1998 honda civic hx
For a while I was able to get A lod of 57 while at 17 tps in 5 gear. However, now it seems that I'm only able to get the lod at 60 or 61. Nothing has changed. I haven't done anything to the car. Thanks
Old 07-10-2014, 01:52 AM   #2 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
What's lod?
Old 07-10-2014, 10:50 AM   #3 (permalink)
RobertISaar's Avatar
MC SBX - '95 Chevrolet Monte Carlo LS
Last 3: 29.75 mpg (US)
based off of raw numbers with no scale, sounds like manifold pressure in kPa?
Old 07-10-2014, 11:04 AM   #4 (permalink)
There is a reason why TPS and LOD are different numbers. A given TPS will not always give you the same engine load. There are way too many variables including rpm, air temperature, humidity and more.
Old 07-10-2014, 10:13 PM   #5 (permalink)
Come to think of that, I remember looking at the air filter to see if it was clean. Do you recommend k&n air filter for reduced lod?
When it gives me lighter lods I'll have to see what else is going in then
Old 07-11-2014, 12:14 AM   #6 (permalink)
a k&n is great if you hate efficient filtering.
The Following User Says Thank You to RobertISaar For This Useful Post:
Mustang Dave (07-11-2014)
Old 07-11-2014, 01:28 AM   #7 (permalink)
I'm not sure what that means
Old 07-11-2014, 01:33 AM   #8 (permalink)
k&n air filters don't filter air very well.
Old 07-11-2014, 06:56 AM   #9 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Keep the stock filter for best MPG. K&N filters may benefit high performance enthusiasts, but not any real benefit if max MPG is the goal.
Surprisingly a dirty filter has no affect on fuel economy with EFI engines, as the computer will adjust A/F mixture accordingly. It does make a difference on carbureted engines though.
http://www.fueleconomy.gov/feg/pdfs/...02_26_2009.pdf
Old 07-11-2014, 07:19 AM   #10 (permalink)
What brake pedal?
Yep, the K&N won't catch finer particles as well as a stock filter. Avoid K&N if you want the engine to last a L-O-N-G time.
The Following User Says Thank You to digital rules For This Useful Post:
