Old 12-07-2012, 11:23 AM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by YeahPete View Post
Mr Crews is right.
195/65/15:
195 = width of tire in millimeters
65 = ratio of height to width in %
15 = rim size inches
His new tires are narrower.
Thanks!!!!
I always forget the specifcs!!!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-07-2012, 11:53 AM   #12 (permalink)
mcrews's Avatar
tirerack.com
here is the search by size:
Search for Tires by Size
here is the specific tire:
Tire Search Results
see at the bottom of the description where it says 'spec'? click it and you get this.....
Hankook Ventus R-S3
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-07-2012, 12:37 PM   #13 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
195? You could easily run 175's on a 6" wide wheel. I have 155's on a 5.5".
Old 12-07-2012, 02:56 PM   #14 (permalink)
mcrews's Avatar
how bout 12 inch wide!!!!????
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-07-2012, 03:29 PM   #15 (permalink)
That rear arch needs a skirt (or kilt )
Old 12-07-2012, 04:40 PM   #16 (permalink)
Sven7's Avatar
Something a little more aero perhaps?
Old 12-07-2012, 05:17 PM   #17 (permalink)
mcrews's Avatar
ohhhh.....arent those the trans-am wheel!!!!!??????
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-07-2012, 05:21 PM   #18 (permalink)
mcrews's Avatar
be careful what you ask for Karl!!!!!!
rims stick uot past the tire and the 'kilt' (flare) just covers the tire!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 12-07-2012, 05:52 PM   #19 (permalink)
sidewall
OK Thanks
I am not fixating, I am just curious
My thought process is that looking at the wifes A2 (15" pepperpots with 185/60/15's) the wheel and tyre have a fairly straight profile, kind of like when people use pizza trays to improve the aero.. Mine seems to look a bit more like a donut so was curious if I would be better off with a wider rim to straighten up the sidewall a bit. Swapping wheels is relatively cheap as they never fail to sell on Ebay
Quite a while back,the 'NEW' metric radials were becoming OEM equipment on passenger cars.
Pirelli had the lowest LLR tire of the day,and the sidewall was fabricated with the curvature 'built in' to create a better air-spring when run at the higher forecast inflation pressures so as not to beat the car,nor occupants to death.
My under-informed opinion is not to be concerned about the 'balooning,' that it is a necessary evil in the quest for LLR and as mentioned by others,that aerodynamic palliatives can be added to compensate for increased perturbation of the local airflow around the sidewall.
Old 12-07-2012, 05:56 PM   #20 (permalink)
mcrews's Avatar
Aerohead,
please re-write that.....there are toooo many multi-syllable words for me
ECO MODS PERFORMED:
First: ScangaugeII
