04-11-2011, 06:53 PM
#11 (permalink)
please delete this double post. I do apologize for my negligence.
#12 (permalink)
Originally Posted by COcyclist
My Mk IV has a bunch of 15mm plastic plugs in the underbody. I keep staring up at these on my back trying to come up with a way to attach my belly pan without drilling into the sheet metal.
You could screw into them, OR remove them and put in an appropriately sized expanding rubber freeze plug and put the belly pan material between the big top washer and the nut. You might want another washer in there.... Or, I'd probably use the freeze plugs to mount some simple aluminum cross-pieces and then attach the belly pan to the aluminum.
04-12-2011, 09:47 AM
#13 (permalink)
Aero Wannabe
Thanks Bill, Since I posted that response I have done the coroplast belly pan, screwing into the plugs with screws for metal roofing. I have been a slug about starting a new thread but I do have photos uploaded. If you click on COcyclist above my avatar, it will take you to my profile and then open the album "belly pan". Of all the aero mods I have done so far, this seems to make the most difference.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
04-12-2011, 01:51 PM
#14 (permalink)
Oh, cool. I like it very much. The wooden blocks on the jack stands in picture 5 are a little scary... But the belly pan is very nice. Did you do anything to protect it from the heat of the exhaust?
04-12-2011, 02:24 PM
#15 (permalink)
Aero Wannabe
The coroplast is in direct contact with the exhaust pipe in a couple of spots and it hasn't been a problem. The catalytic converter is open to the air but diesel exhaust is much cooler than gas cars.
TDi=fast frugal fun
04-13-2011, 05:40 AM
#16 (permalink)
Nice work
i wonder why did you space the tray from the bumper?
Is this for cooling or venting or to get a certain angle? i have a similar rear tray, but the spare wheel tub extends below the rear buper that's fairly high, and so the tray curves up to meet the bumper
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
04-13-2011, 03:38 PM
#17 (permalink)
I didn't know that about diesel exhaust. Interesting. My Honday Element's exhaust will melt coroplast allllll the way out to the tip of the tailpipe...
04-13-2011, 06:30 PM
#18 (permalink)
I agree with CoCyclist, my exhaust is not really hot enough to melt it...
If you have a turbo car with an intercooler, which I don't (yet, watch this space for the addition of a Mini Cooper S intercooler) then the exhaust gas temp is drastically decreased.
I like your full width tray CoCyclist. I may extend mine in a similar fashion (leaving the cat open).
Just a 500 mile drive on motorways (nice and hot for engine + exhaust) to test it out, and I'll probably have some MPG results.
@lunarhighway, the spacing is only to allow me to change the angle, my fuel tank sits low and without spacers, the tray goes straight to the bumper at quite a steep angle. The rear portion of the tray is pretty much sealed at the front edge, so not much venting will happen.
The reason for the current gap is simply that was the length of bolt I had lying about. I probably need longer.
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
04-14-2011, 10:16 AM
#19 (permalink)
Aero Wannabe
Thanks, the 4' x8' salvaged sign went from the back bumper to the cat and almost from seam to seam on the rocker panels. I got lucky.
There is a thread on here about diffusers and some charts showing that drag is lowest at about a 4 degree rise to the back edge of the diffuser (belly pan).
TDi=fast frugal fun
05-01-2011, 12:50 AM
#20 (permalink)
Nice work! Looks like a politicians race car now underneath. My question is, how much of a difference did it make? Could a mod like this cut down on road noise too?
... and the result is what?
I like your mod too btw.
