Old 07-27-2014, 02:35 PM   #171 (permalink)
Master Novice
elhigh's Avatar
Josie - '87 Toyota Pickup
90 day: 40.02 mpg (US)
90 day: 49.62 mpg (US)
Hey Bob,
Perhaps you could check your rhetoric just a tad. Sendler's been here for a while now and by his numbers doesn't appear to be completely clueless - whereas you have not "put up" at all.
Sendler:
I think the decomp lever is a great thing to control from inside the car. For starters CJ posted some bonkers numbers in his GGP, so he must be doing everything, or nearly everything, right - including the decomp control.
Triggering the decomp while coasting will take a lot of drag off the engine, whose rotating mass then adds its inertia if left in gear to the car and make it glide after downhills as if it were a larger car. Not only that but it will also do a fair amount of air cooling which may help prevent the electric fan coming on during operation, a not-insignificant savings.
Old 07-27-2014, 11:17 PM   #172 (permalink)
Growin a stash
The key point is the governor cuts off fuel during deceleration, so this is better than idling. I want to know, could it work on gas engines? I don't see why not, if they had a decomp valve and the spark and fuel were cut off.
Old 07-28-2014, 08:59 AM   #173 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
I didn't think the governor could interrupt injection that far from redline.
Old 07-28-2014, 09:22 AM   #174 (permalink)
Master Novice
elhigh's Avatar
I imagine the injectors automatically cut out as long as the decomp lever is open, though, right?
Old 07-28-2014, 07:18 PM   #175 (permalink)
As a member of this forum, mostly in silence, I have stumbled onto some very good threads, which this is one of. My hat's off to the diligent work & persistence that has gotten your project to the level it is. I also belong to a VW diesel forum, which we make reference to this forum when applicable. Usually when mileage becomes the subject. There is a lot of threads on the diesel forum which talk, in depth, about injection pumps, how they work & how to modify, which I believe would be good info for people who use diesel engines for their high mileage vehicles. After reading this thread, my only suggestion would be to see how much better the mileage would improve with a few more aerodynamic enhancements, because I believe you are close to the maximum efficiency of the power plant you are using in your current configuration. Please don't take this as a negative suggestion. I believe you've done an outstanding job.
Old 07-28-2014, 07:50 PM   #176 (permalink)
I think the Centurion would be a perfect model car for mass production in China or India. Small, inexpensive, reliable low tech, high efficiency, low emissions, and good looks. There are a lot of junky cars over there polluting like crazy. The only issue would be the lack of storage space. They sure do like to pile high cargo.
You know people haven't learned from the past when the old becomes new again! lots of people talk about sustainability but very few live it. I've been fortunate to meet many of them from this site.
I try to be helpful. I'm not an expert.
Old 07-28-2014, 09:55 PM   #177 (permalink)
The body style and drive train could easily updated to get more cargo space. A long tail Mercedes-Benz C-111 frequents my day dreams. A change in injectors and such would allow for natural gas fuel.
Old 07-28-2014, 10:24 PM   #178 (permalink)
Changfa diesel + Suzuki
changzuki's Avatar
Centurion - '74 FIAT X1/9 Centurion Full Race DNA
Last 3: 143.5 mpg (US)
For those of you who've followed this thread and/or responded - thank you!
Whether we agree or disagree in the end we all benefit one way or another from the shared information and this is why the ecomodders kick-azz when they show up to an invite!
My opinion is and always has been, you have to learn to crawl before you can walk so although information is free, at some point it should be twined with actual hands-on experience. Hopefully from that point a further learning ensues but only through persistence..
I read and either learn, or shore up my current knowledge through posts here on ecomodder but make no mistake; nothing on here is even remotely close to how hard I critique my own work - so don't worry about that - let'er fly!
A few pointed responses:
"Sendler wrote - And, isn't the injection pump still spraying fuel right out the tail pipe at the idle quantity times the rpm anyway? Better to just let it idle if you don't want to shut it off when coasting."
No. As I stated, fuel delivery is cut to the injector in a situation when the accelerator is allowed to remain weight free of my foot and the car's momentum is driving the rotation of the engine beyond that. I'll reference a video I uploaded just for you. It will demonstrate this principle - one I've watched in my house for years now. Stay tuned... Secondly, if you ever get the opportunity, get up close to an idling diesel and watch the things that are attached to the engine such as the dipstick, any bracketry, etc... The vibration at the diesel idle you're suggesting is phenomenal and can often lead to work hardening of those metals to the point of stress cracks and breakages. Diesels typically are idle friendly (smooth) up around 1250 or so. At the Green Grand Prix Centurion was vibrating from front to rear at idle - yes, the entire windshield was pulsing. Audibly this little engine could be heard above anything else there. I have no desire to idle this diesel when it's unnecessary to do so. (The soot blow-by into the oil pan at idle is another story but that's some other post..) A decompressor is as I mentioned a neat compromise and it works exceptionally well. The decompressor in the video is illustrated nicely at the end of the video showing many rotations of the engine after the fuel is manually turned off and the decompressor engaged - just like at the Green Grand Prix.
To BobS -
"Elhigh wrote - I imagine the injectors automatically cut out as long as the decomp lever is open, though, right?"
Not exactly. As long as the momentum of the car is driving the engine rpm beyond what the accelerator pedal is telling the governor, then fuel is automatically shutoff to the injectors by the governor. If the governor is held at this position manually and not allowed to recover as rpms drop from say pushing in the clutch, the engine will quit (it's starved for fuel). When I know fuel is cut to the injectors by the governor, then I take over and touch the horn button with my big toe and activate the decompressor. It's like having a huge tailwind come out of nowhere when you release engine compression. (Kubota D850 is well over 400 psi per cylinder. As a kind of comparison, it takes a bit of horsepower to run a one-lunger air compressor or auto airconditioner compressor for that matter.) This is a good question though because there are ways to automate the process as you've suggested - but in this case I'm part of the "automation".
"shorttimer wrote - ....After reading this thread, my only suggestion would be to see how much better the mileage would improve with a few more aerodynamic enhancements, because I believe you are close to the maximum efficiency of the power plant you are using in your current configuration. Please don't take this as a negative suggestion. I believe you've done an outstanding job."
shorttimer, Thank you for your kind words and I completely agree with you. The heart of a diesel lies in its fuel delivery system - it's a biggie. Also agreed, there's plenty of ways to improve Centurion and those aerodynamic items were intentionally left off the list. My reasoning for staying clear of those is two-fold. First I never wanted to drift too far from RQ Riley's original plans. At what point is it no longer the cover car from Feb 1982 Mechanix Illustrated? The other reason is the aerodynamic items such as those here on ecomodder are "givens", basically tried and true. My experience is when I spend time on the obvious, I either overlook or completely miss other important areas. So, this is kinda like working from the other end of the number line. This also leaves to the door totally open for some other ambitious soul to best Centurion - someday - but they will need to employ all the tricks of the trade and maybe even a few that aren't popular yet. The bar is high but certainly not out of reach. Thank you for your post!!!!
"sheepdog 44 wrote - You know people haven't learned from the past when the old becomes new again!"
So you've just described 9 Main Street in Colton! If I didn't agree wholeheartedly I wouldn't keep reviving some of this primitive technology and running with it just a little! Bravo!
--Ok, let me try to get to the next post to reference the governor video. This should help clear up some of the mystique of how these behave on working engine that you can see....
BRB...
~CrazyJerry
The Following User Says Thank You to changzuki For This Useful Post:
BobS (07-31-2014)
Old 07-28-2014, 10:33 PM   #179 (permalink)
changzuki's Avatar
Listeroid Governor in Action!
In this working example, watch the yellow bread-tie as it comes in contact with the fuel pump body. When this happens (either manually or via the governor) fuel is effectively cut to the injector and if held in this position the engine will quit. Watch where I do just that - I hold the position the governor took when the rpms were too high and I do not allow it to recover/correct when the rpms come down Just short of the engine quitting, I let go and let it recover to it's 275 rpm setting If I get too ambitious and manually engage the fuel shutoff all the way, the bread-tie will jam into the pump body and you'll see it bend.
The blackout in the earlier part of the video (around 1:30ish) is my inability to hand-start the engine while holding the cell phone so you can guess what I did! Amateur video at its best!
Bottom line - fuel delivery to the injector can be effectively stopped by the governor when engine momentum exceeds governor setting (weights or whatever..)
Centurion's engine governor (Kubota D850) works the same way. The visual confirmation is the loss of injector pulse to the tiny tach and rpms drop out of the screen display...
At the last 15 seconds or so of the video, I manually shutoff the fuel delivery to the injector at the pump. Then I engage the decompressor. If I didn't do that the flywheels would only rotate a few more times before compression ground them to a halt. By relieving this cylinder pressure the flywheel momentum carries the rotation for many more revolutions (and keep in mind by the time I kicked in the decompressor the rpms were down under 100...
The link to the video on youtube is:
Listeroid Governor Cutting Fuel Delivery - YouTube
~CrazyJerry
BobS (07-29-2014)
Old 07-29-2014, 06:17 AM   #180 (permalink)
sendler's Avatar
I was thinking automotive diesel but your commercial diesel engine must have a regulating governor designed to hold steady rpm under varying loads. Makes sense about not wanting to suffer the extreme vibration from an engine not really meant to idle very often.
urba centurion
