Old 03-17-2011, 11:22 AM   #141 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
Thanks, KITT!
Here are a few more details in case anyone is thinking of doing this, too. First I drilled through the thin shell of the acorn-style lugnuts.
Then I was able to convince 10-24 lock nuts down past the threads of the lugnuts, and I threaded in a screw/jam nut/washer combo into the lock nuts. To hold the locknut inside the lugnut, I had to jam in one jaw of a needle nose plier while I threaded it in. Then I snugged down the jam nut so it looked like this;
Next I smeared that nasty silver anti-seize stuff all over the threads of the lugnuts and the threads of the 10-24 screws that were poking above the locknuts. Then I poured in some J-B Weld thinned with acetone and let them cure for 24 hours.
Kinda fiddly and tedious, but it worked.
I also got some vinyl tubing from Lowes and slit it. I put this around the perimeter of the pizza pans so it won't chaffe my alloys.
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
Daox (03-17-2011)
Old 03-17-2011, 03:17 PM   #142 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Heads up, the tubing will come off over tme. Mine happened on the makanaw bridge. They made a racket as they Wendy. Thump on every revelution. I tried gluing thembon but that did not hold. I found that 2" chunks worked better.
Old 03-17-2011, 08:52 PM   #143 (permalink)
Ecomodder en route
KITT222's Avatar
Vib - '04 Pontiac Vibe base
Idea to prevent the tubing from coming off: Get something like a large rubber band, or even just tape, and stretch it across the cover in multiple spots, so the band helps hold the tubing on. That way the tubing won't eventually be thrown off via centrifugal force.
Old 03-17-2011, 09:10 PM   #144 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
What about just using grease?
Old 03-17-2011, 09:15 PM   #145 (permalink)
Wiki Mod
Then they will come off faster.idealy we.need to coat the edges in plastic. Tubing is cheep but not a full.circle.it has a seam. Which fails.
Old 03-19-2011, 02:42 PM   #146 (permalink)
Deadly Efficient
Thanks for the heads-up, Weather. I've got the seam glued with clear silicone, but I'll keep an eye on 'em.They're pinched pretty good between the pan and the wheel...so far so good. If they do come undone, maybe Plasti Dip would work, instead.
-Terry
Old 03-19-2011, 05:04 PM   #147 (permalink)
Does that come in clear?
Old 03-21-2011, 09:35 AM   #148 (permalink)
Deadly Efficient
I don't think so. I'd probably use black. But I'll cross that bridge when I get to it.
-Terry
Old 03-21-2011, 12:19 PM   #149 (permalink)
Liberty Lover
j12piprius's Avatar
I thought the screws held them on?
Old 03-21-2011, 06:32 PM   #150 (permalink)
Wiki Mod
The screws hold the pizza pan on, but the tubing is just slid over the edge of the pan. the tubing will end up coming off.
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
