Old 06-27-2021, 03:10 PM   #71 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Testing is finished for now.
13,9kWh at 100 km/h speed. Tesla Björn got same consumption at 90 km/h with stock car.
On my own short test route results are over 20% better than with stock car.
Still room for more, but will fly back to germany tomorrow...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following 4 Users Say Thank You to Vekke For This Useful Post:
aerohead (06-30-2021), freebeard (06-27-2021), Joggernot (06-28-2021), samwichse (06-27-2021)
Old 06-27-2021, 03:22 PM   #72 (permalink)
I hope that is acceptable to your critic.
Old 06-27-2021, 03:34 PM   #73 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
3500km driven in 3 weeks only testing. 100km run could have been 0,3 to 0,4kWh better without any other cars. Just tire spats over 15 different versions.
More pictures at facebook of the final look.
There was still more mods to be done, but no time to execute them.
aerohead (06-30-2021), freebeard (06-27-2021), Isaac Zachary (06-27-2021), samwichse (06-27-2021)
Old 06-27-2021, 05:20 PM   #74 (permalink)
I must have missed this. What's the green part on the A-pillar?
(Please say plasma actuator. )
Old 06-27-2021, 10:48 PM   #75 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Green tape which lowers panel temperatures which leads to lower inside temps which leads to less need for cooling. Specially on the roof.
The Following 2 Users Say Thank You to Vekke For This Useful Post:
aerohead (06-30-2021), freebeard (06-28-2021)
Old 06-29-2021, 06:35 AM   #76 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
In this condition my ID3 is about 20% more energy efficient than the stock model. Drag coefficient Cd is under 0,22 based on my own calculations of the performance.
Mod list:
30mm lowering, (40mm would be optimal)
Optimal wheel angles for efficiency
air curtains at front
A arm covers front and rear
Front tire deflectors front and rear
Grill block
155/70r19 tires @ 4.0 bar
Fully blocked curved 19" wheels
Dampening at wheel wells and doors
Taped roof
And efficient driving of the car
With these tires the A arm panels could have been much bigger
Aircurtains should be fully closed inside the fender, now the upper side was still open
Tire deflectors still have room for improvements even i built 15 versions of them already.
could build deflectors behind the tires
wipers center part needs a plastic
Kammback could be extended
Rear diffusor could be extended
Rear tires could be built a skirt to cover whole wheelwell
window tinting would help to boost the efficiency also or PC windows
Sideview mirrors could be changed to cameras (would help a lot also to wind noise)
Few other speciall tricks to try that cannot be shared at this time.
https://youtu.be/EDYYMPKPSKs
The Following User Says Thank You to Vekke For This Useful Post:
Old 06-29-2021, 06:53 AM   #77 (permalink)
alexshock's Avatar
Auris - '16 Toyota Auris
90 day: 38.33 mpg (US)
Hyundai - '20 Hyundai i30
90 day: 28.55 mpg (US)
On your video you mention white film on the dashboard and green film on the roof.
Why don't you use UV-film for that? You can just cover the whole windscreen (and probably side windows) and it will be much cooler inside the car.
Old 06-29-2021, 07:09 AM   #78 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Yes they have clear films even for meant to be used in windows. Plan was to test those for window noise, but did not have time for that. They would also keep interior much cooler if to put all window areas.
At the moment tire noise is so low that only wind noise is bothering most...
But the costs are out of my reach at this point. whole car over 1000€.
I have tinted acryl for windows, but again no time to built them. In the A8 I had rear door windows plastics and they worked fine.
Old 12-07-2021, 10:14 AM   #79 (permalink)
IRONICK's Avatar
https://airshaper.com/research/from-...-optimized-car
The Following 3 Users Say Thank You to IRONICK For This Useful Post:
aerohead (12-09-2021), freebeard (12-07-2021), samwichse (12-08-2021)
Old 12-10-2021, 05:42 AM   #80 (permalink)
Originally Posted by Vekke View Post
I will soon get my own first eletric car and it will be the VW ID3
Frontal area is 2,36m2 and announced drag coefficient Cd 0,267............
Roofline of the ID3 matches perfectly the ASTII template so the bad aerodynamics come from wheels and underside of the car as the front already has a active grill block on all models. Will look closer is it full grill block or not when I get the car................
I was not familiar with this car, thank you for posting about it.
The Aerodynamics of the VW ID.3 Electric Car
https://link.springer.com/article/10...311-020-0270-5
Top image with a top view is most refreshing to see.
09 September 2019
VW ID.3 debuts as people's electric car with up to 342-mile range
https://uk.motor1.com/news/369750/vw...led-frankfurt/
Strangely, the model is a no-go for the United States.......
The smart packaging also allows for a low frontal drag coefficient of just 0.267, while the minimum curb weight is 1,719 kilograms...........
Odd front lower valance corner treatment and details.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
aerohead (12-13-2021), COcyclist (12-19-2021)
aerodynamics, energy consumption, id3, lower drag, range improvements
