Old 09-25-2012, 06:06 PM   #1 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Vx d15 questions (VX vs DX trans)
I am wondering what the fuel economy difference is between the taller 5th gear VX transmission compared to the 5 speed from a DX? I found a Civic with a D15z1 in it, but I'm pretty sure it is still the DX transmission, and wondering how much it is leaving on the table, fuel economy wise.
Is there anything else to consider about a swapped Z1, I'm guessing the ecu has to be from the z1, anything else?
Thanks in advance.
Old 09-25-2012, 06:28 PM   #2 (permalink)
2000neon's Avatar
Also, could you guys confirm that this is a D15Z1? I have always told them apart by the oil cap on the top corner, the spark plug location, and the valve cover. So to me this seems to fit, but I want to be sure, and I have asked the seller about engine code, but waiting to here back.
... And yes I would probably switch the header to a manifold if I were to buy this.
Edit: maybe I should add the pic,
Old 09-25-2012, 08:23 PM   #3 (permalink)
turbothrush's Avatar
2 x wrecked vx - '92 Honda Civic Vx
90 day: 62 mpg (US)
Thanks in advance.
I would say your going to loose 4 to 5 mpg in 5th gear at 55mph.
Also the D15z1 had egr with a control box but I would not bother with it unless you need it for emissions.
Old 09-25-2012, 08:35 PM   #4 (permalink)
2000neon's Avatar
Oh wow that much?! Do you think it could pass emissions without the egr control box? How much of a hassle (and money) is it? Would not having egr hurt its fuel economy?
Old 09-25-2012, 08:53 PM   #5 (permalink)
2000neon's Avatar
He said that it is a "d15 mini-me" swap. I am totally new to hondas, and im searching but having a tough time understanding this mini me swap. So it is not a d15z1? It is the engine pictured above.
Edit: it appears this is probably a d16y8 head....
Old 09-25-2012, 09:07 PM   #6 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
That looks like the intake manifold for the vtec and vtec-e engines in the VX, HX, and EX trim levels. On the transmission, I am not sure how much you would lose or gain. But at least a couple at steady cruise seems certain. It's a mod I would want, and do want, and I have been shopping for a VX/CX transmission. On the EGR, my understanding is that the purpose is partly to reduce pumping losses, which would be good for FE. As for "mini me" ... "It's when you take a D series non V-tec block, and bolt on a D series V-tec head. Doing so, you gain HP, a bit of higher compression, and V-tec" (says this guy who did it). That does not sound good for FE. The DX block would not have EGR, so if this engine does not have a spot for EGR, I guess you are looking at a DX block with VX (vtec-e) parts added on. Avoid?
Old 09-25-2012, 09:21 PM   #7 (permalink)
2000neon's Avatar
Well this to me sounds like I'm going to pass on it... I will keep searching and waiting for a decent vx to pop up. Someday I will find one..
Old 09-25-2012, 09:25 PM   #8 (permalink)
My stock VX would do 30 MPH at 1000 RPM in 5th gear, same as 90 MPH at 3k RPM in 5th.
regards
Mech
Old 09-25-2012, 09:32 PM   #9 (permalink)
2000neon's Avatar
Wow that is a seriously deep gear. That to me says to avoid this car as well, too many things I want to change, work on, improve, etc.
Old 09-25-2012, 09:42 PM   #10 (permalink)
Enthusiast
Mini me is a 6z head on a d15 block. It's a speedy setup, not terribly efficient. That car would only get 32-35 mpg mixed.
The Following User Says Thank You to hondaguy72 For This Useful Post:
Ryland (09-26-2012)
