Old 11-04-2012, 09:08 AM   #51 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
Hill billy,
Please report back!
Originally Posted by Hilly-Billy-13 View Post
I haven't played with the Futurelec units yet, how ever I think the figures for the Bio-Tech units are correct. I've ordered a Futurelec unit to see how well it works on both sides of my Diesel Rabbit
Bill
Noah Webster, 1787
Old 11-05-2012, 09:22 PM   #52 (permalink)
Originally Posted by Varn View Post
Hill billy,
Please report back!
I ordered 2, I figured it's be easier to compare apples to apples, as opposed to apples to avocados. Meaning I can see both sides of the fuel usage at the same time
Bill
As of today 11/24/2012 I still haven't received them
Old 11-06-2012, 01:15 PM   #53 (permalink)
HypermilerAX's Avatar
AX - '95 Citröen AX
307 - '04 Peugeot 307 SW
Be sure the flowmeter can handle high enough flows.
I have a small 1.5 diesel engine with 58 hp and when I drive at 50 mph I have roughly 30 lph on the supply line and 25 lph on the return.
Citroën AX 1.5 D 430.000 km
Peugeot 307 SW 2.0 HDI 136 195.000 km
The Following User Says Thank You to HypermilerAX For This Useful Post:
Hilly-Billy-13 (11-06-2012)
Old 11-06-2012, 01:26 PM   #54 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
I think I'll pull my return line and set it in a bucket, to see just what I will be dealing with.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 11-06-2012, 10:45 PM   #55 (permalink)
That gives me a good reference point, mine is also a 1.5L Diesel. You wouldn't happen to know what your flow rates are at idle would you?
Thanks
Bill
Old 11-07-2012, 02:31 AM   #56 (permalink)
AX - '95 Citröen AX
Sure. At idle, I have 18 lph on the supply line and 0.5 lph less on the return line.
It's a naturally aspirated engine from the 90's with a mechanical injection pump.
Old 11-07-2012, 09:14 AM   #57 (permalink)
Do more with less
Edit
That is pretty amazing .5lph to idle
Who would have guessed that the flow rates are as high as they are.
Noah Webster, 1787
Old 11-07-2012, 09:47 AM   #58 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Edit
that's better than a Gasser. 1.6l in the civic would idle at .25 gph according to the MPGuino.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-13-2012, 04:51 PM   #59 (permalink)
I just purchased a few of the FLOWFUEL30L0 flow meters and I am having some trouble reading the output signal. How are you guys getting a reading? My application is not in a car, it's an inline fuel measurement system for a dyno. I'm in the testing phase right now, I just got the meters. I can't figure out how to read these pulses and make it a useful signal that I can read.
Old 11-15-2012, 10:34 PM   #60 (permalink)
Futurlec sensors
rodeo1314
The Futerlec & most low cost fuel flow sensors use a digital output "Hall Effect" sensor. They're defined as an open collector output, what this means is the 3 wires are hooked up as follows Red goes to the positive side supply, if your using a Arduino or similar, use 5 Volts, the Black goes to the minus side of your supply. The you need a resistor between the positive side of the supply and the white wire which is your output. I've seen values from 10 K on down, some arduino pins have a pullup resistor as an option. I haven't received my sensors yet so I can't say for certain what value of resistor is needed.
Bill
Oh yes back in the mid to late 70's & early 80's I did some work on Dyno instrumentation I wish I'd had access to the sensors we can get now.
