Old 01-05-2020, 05:52 PM   #101 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Just recently reinflated my tires to 55+ psi (cold). Been doing that since 2010 or 2011. My tired run and run. No blowouts. I rotate tires pretty occasionally. Wear is fairly even. Just my experience.
EcoCivic (01-05-2020)
Old 08-08-2020, 08:53 PM   #102 (permalink)
Cyborg ECU
Garage 54 gets the last word:
The Following 2 Users Say Thank You to California98Civic For This Useful Post:
EcoCivic (08-08-2020), Gasoline Fumes (08-09-2020)
Old 08-08-2020, 09:53 PM   #103 (permalink)
Lol yeah I saw that
Old 08-09-2020, 04:28 AM   #104 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
220 PSI
In Soviet Russia tire destroys pot hole.
The Following User Says Thank You to jakobnev For This Useful Post:
Old 08-10-2020, 07:37 AM   #105 (permalink)
Prophecy99's Avatar
Maxima - '02 Nissan Maxima GLE
i used to ride on 52-54 psi, but on my set up (spacers, low profiles , upgraded side wall tire size) i started getting way to extra wear in the center of the tires and none on the outside.
so just make sure you are watching you wear closely if you have anything from stock set ups.
i am running low 30s now to compensate for the bad wear I was getting, economy...no not really, but you could look at going through tires quicker as a waste of money too and at the end of the day it is economy to save your tires and get better conistent tread wear.... blah blah....
kinda off topic, but ultimately just watch your wear when messing with tire PSI
i didn't notice too much MPG from going to low 50s by the way, and it was pretty stiff and rough.
not worth it to me, id rather coast and have better driving practices for MPG, and aerodynamics
The Following User Says Thank You to Prophecy99 For This Useful Post:
EcoCivic (08-10-2020)
Old 08-10-2020, 07:08 PM   #106 (permalink)
I use the highest tire pressure I can and still get even tire wear. With Michelin Energy Savers I'm using 50 psi on 225/50-17 on my FORD CMAX
Paul
