Old 07-15-2015, 03:51 AM   #31 (permalink)
The PRC.
*whether
The Following User Says Thank You to Arragonis For This Useful Post:
Ecky (07-19-2015)
Old 07-15-2015, 12:12 PM   #32 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Originally Posted by IamIan View Post
Net global population growth rate has reduced (slowed) to ~1/2 of the rate of growth it was .. including a ~30% increase in life expectancy over the same time period .. If not for the increased life expectancy .. the rate of growth would have been about ~1/4 of the rate is was previously .. this well documented slowing is progress in the correct direction.
I'll point out again that, while our rate of growth has been halved from what it was 50 years ago, our net growth in absolute numbers per year is still very close to the highest it's ever been, at more than 135 million humans/year. Expressing this growth as a rate of the total population is misleading, as that population is so much larger today than it was just a few decades ago that, despite maintaining the same absolute growth numbers, rate of growth will appear to slow unless we "ramp up production," so to speak.
Edit: my argument being that we have made no progress on controlling our population growth, which is clear when you look at absolute numbers rather than percentage growth rate.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 07-15-2015, 01:08 PM   #33 (permalink)
90 day: 35.79 mpg (US)
Is there a way to /ignore threads? I would hate to click on this again and need to execute a palmface.
Heh. Maybe I should have asked elsewhere...
Old 07-15-2015, 06:03 PM   #34 (permalink)
The PRC.
Originally Posted by Vman455 View Post
...Expressing this growth as a rate of the total population is misleading, as that population is so much larger today than it was just a few decades ago that, despite maintaining the same absolute growth numbers, rate of growth will appear to slow unless we "ramp up production," so to speak.
No, it is not misleading. Why ?
Question, what population did Malthus see as doom, and crucially why does he remain wrong?
Old 07-15-2015, 06:32 PM   #35 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
Binarily saying "malthus was wrong", you might as well say we will never have anything to worry about ever, because some technological miracle is just around the corner, and there will never be any limit or unintended consequences (perhaps catastrophic) to adoption. Unfortunately "malthus was wrong" is all folks can come up with in response. It is a set of blinders at best.
lets not forget about diminishing returns.
Old 07-15-2015, 08:21 PM   #36 (permalink)
IamIan's Avatar
You are welcome to look at it anyway you like.
If we agree or not.
I see a reduced % rate of growth as progress in the correction direction.
The absolute numbers rate you describe is only a larger magnitude (same direction) rate of reduced % growth rate .. for any size population.
% growth rate = absolute number gain / total population
For Example:
100 @ 1% growth rate = 101 = gain of absolute +1
101 @ (1/101)% growth rate = 102 = gain of same absolute +1
102 @ (1/102)% growth rate = 103 = gain of same absolute +1
etc ... etc...
100 @ 10% growth rate = 110 = gain of absolute +10
110 @ (10/110)% growth rate = gain of same absolute +10
etc ... etc.
Same thing give you what you describe for any size population .. or any magnitude of rate of (absolute growth)
For the rate of % growth to be at this rate of reducing you ask for ... the total net today of about 1/3 the previous % growth rate .. instead of the ~1/2 previous % growth rate we did ... ie you want 'faster progress' in order to reach the rate of progress you want to call progress.
Ironically ... without the ~30% increased life expectancy .. we would have reduced the % growth rate faster and further to 1/4 .. more progress than the rate of % growth reduction you are asking for (1/3).
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
Old 07-15-2015, 10:59 PM   #37 (permalink)
P-hack's Avatar
"progress" seems like a strange term to color things with. Progress towards what exactly?
Old 07-16-2015, 03:05 AM   #38 (permalink)
The PRC.
Why is it misleading ?
Old 07-16-2015, 05:53 AM   #39 (permalink)
IamIan's Avatar
Progress toward sustainable human population correction.
1st step of progress toward that is to reduce the rate of acceleration in the 'wrong' direction .. which is exactly what we have been doing.
We have to define what direction of this % growth rate is 'correct' or 'wrong' direction.
% growth rate has only 3 possibilities.
#1> Reduce
#2> Stay the same
#3> Increase
I say #1 is the correct direction = direction of Progress .. The other directions 2 or 3 that would be the 'wrong' direction and thus not the direction of progress.
As I've said before.
Weather it is a 'fast enough' rate of progress .. or weather this type of progress will continue 'long enough' ... only time will tell.
Those other two questions (fast enough, long enough) , are asking details about the magnitude and duration of this direction of progress.
If you want fewer total number of people .. the 1st step of progress toward that would still be to reduce the rate of +% growth .. ie you have to slow down 1st before you can go in reverse.
Old 07-16-2015, 08:49 AM   #40 (permalink)
P-hack's Avatar
What I want, or what you want, and what everyone else wants, are very different things.
lies, scam
