Old 02-02-2019, 10:21 AM   #21 (permalink)
I think CHEVY uses a dual nut for hubcaps that is 1/2-20 lh internal thread. Use those with whatever chevy uses for retention. Or use really long lugnuts with the closed ends tapped & threaded.
Old 02-10-2019, 09:50 PM   #22 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Originally Posted by Taylor95 View Post
Using a magnet to attach moonhubs is a very ingenious idea. Do you think it will be safe at highway speeds?
It's been done on this forum and failed - but enough magnets should eventually do the trick. You can buy magnets that will hold 100's of pounds of weight, but they cost 100's of dollars.
Gluing magnets means two potential points of failure, the magnet to magnet interface, and the glue itself. The coatings on cheap rare earth magnets fail, and then the magnets crumble. Quality magnets are expensive.
A flying disc can do a lot of damage, and in the era of dash cams you'd want to be certain of your install.
Old 02-10-2019, 10:50 PM   #23 (permalink)
Use sufficient magnets and you'd bend a Moon disk trying to get it off. They're not that thick.
"We're deeply sorry." -- Pfizer
Old 02-15-2019, 04:02 PM   #24 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Has anyone actually tried attaching moon disks with magnets?
Old 02-15-2019, 08:27 PM   #25 (permalink)
I haven't but I have a candidate set of disks. The original three holes were worn out, so I got them for $5 for the set of four at a swap meet.
If I were to implement this, I'd try pulling on the magnet with a 2nd, more powerful magnet and then ring it off.
Taylor95 (02-15-2019)
Old 02-15-2019, 09:55 PM   #26 (permalink)
Those look good. Be sure to let us know how they end up working out!
Old 02-15-2019, 10:11 PM   #27 (permalink)
Swap meet material.
They could stand planishing and buffing. My intention is to sell the Superbeetle as is and put these Marathon/Jubilee OEM wheels on my last remaining Beetle.
Maybe they will wind up on those. I wouldn't want to drill holes in them. My son buys magnets for gaming miniatures in bulk.
https://duckduckgo.com/?q=magnets+for+gaming+miniatures
Old 02-16-2019, 10:51 AM   #28 (permalink)
Planishing? There are welds that need to be flattened by force?
Old 02-16-2019, 12:01 PM   #29 (permalink)
Wouldn't that be hammer welding?
Planishing is a metalworking technique that involves finishing the surface by finely shaping and smoothing sheet metal.
https://en.wikipedia.org/wiki/Planishing
I hadn't thought about welding patches in the notches. Instead I was going to fold aluminum disks like a taco and crimp them over the (12) notches and drill holes in them.
Old 02-17-2019, 03:51 PM   #30 (permalink)
I stand by my definition.
I was wondering what you were beating on.
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
Help with my aero mods: 1.8L 05 Auto Toyota Corolla blackjackel Aerodynamics 73 11-22-2011 09:55 PM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 04:50 AM
how to make skirts for plastic wheel arches? modmonster Aerodynamics 6 01-22-2009 11:06 PM
