Old 07-13-2020, 07:55 AM   #11 (permalink)
tinker
Originally Posted by CapriRacer View Post
First, I am of the opinion that the make and model of tire matters so much more than tire size, that changing tire size isn't worth the cost.
But to address the issue you've raised, a 155/80R13 has an allowable rim width of 4 to 5".
I'm researching the best tire for that. Michelin Energy XM2s or Goodyear Duraplus are on my list currently, Yokohama's Bluearth models too since they are pretty well known for having a balanced ride.
Correct me if I'm wrong, since I emphasize on the ETRTO specified rim width too much may I know what happens when you fit a tire on the widest end of its allowed width? Will have any adverse effects? I know it lessens sidewall flexing, which in turn nets lower LRR. All at the expense of comfort I presume.
Old 07-13-2020, 09:48 AM   #12 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
You will have less difficulty finding the 1996-2000 Civic HX rims then you will the 2000 Insight. The HX rim was only 11.75 lb, but that trim was one of the lowest selling trim lines of the Civic in that era.
Last edited by California98Civic; 07-13-2020 at 11:49 AM.. Reason: "rim" not "room" (silly dictation software).
Old 07-13-2020, 09:55 AM   #13 (permalink)
Tire Geek
CapriRacer's Avatar
Originally Posted by leoblack9 View Post
....... may I know what happens when you fit a tire on the widest end of its allowed width? Will have any adverse effects? ......
There is negligible difference within the allowable rim width range.
CapriRacer
Visit my website: www.BarrysTireTech.com
New Content every month!
Old 07-13-2020, 11:39 PM   #14 (permalink)
tinker
Thank you CapriRacer, so 155/80/r13s are still on the table alongside 165/70/r13 (same diameter as oem) and 175/70/r13.
Update:
I've double checked the Charade wheels and found it that its 13x5 with an offset of ET40. Original offset of the steelies were ET45. That means these rims would stick out 10mm more closer to the fender but would have the same inside clearance towards the suspension components.
Would it be better that I find a similar offset or would a positive offset of 40 (to offset the .5" wider rim) provide similar to OEM specifications?
Old 07-18-2020, 11:43 PM   #15 (permalink)
If the $$ were not important you can build up some 3 piece ones ,, you might fond some at a dirt car swap meet, look for Dwarf car parts..
If it has a motor its worth playing with.......
