Old 08-08-2016, 01:21 AM   #11 (permalink)
So what is our take on the pontification that started this thread. NEVER warm up? Or SOMETIMES warm up if the occasion warrants it?
Old 08-08-2016, 01:31 AM   #12 (permalink)
Originally Posted by me and my metro View Post
Some modern "clean" Diesels inject fuel on the exhaust stroke to heat the cat to burn the soot in the exhaust filter. This regen process works fine if you happen to be driving on the highway. I work for an electric utility and this system has caused a lot of problems when the regen process gets interrupted. Our trucks often run at low speeds and run a power take off to power the boom. The regen process only runs while driving. Unburned fuel ends up in the crankcase diluting the oil. That and all the high pressure fuel system is under the valve covers, if something leaks it stays inside. The oil capacity is 15 quarts and we have to monitor oil level for over level. We have drained as much as 25 quarts of diluted oil from these trucks.
I'd heard Cummins (or Caterpillar?) injects the extra fuel post-cylinder, straight into the exhaust. I still don't understand why other makers don't do this. Doesn't even have to be one of those fancy high-pressure piezo injectors... could be done with a regular old-tech injector.
Old 08-08-2016, 09:14 PM   #13 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
It not a question of warming up or not. The question is if warming up by idling the engine is efficient and does it reduce or prolong the longevity of the engine.
Old 08-08-2016, 10:25 PM   #14 (permalink)
Canadian government is one hella lot more proactive about advising against idling than any entity I've found in the U.S.. Once when researching idling online I found several Canadian sites that advised against it and backed it up with research findings.
The Owner's Manuals I've looked in recommend to drive straight away.
I do that the vast majority of the time. I believe in the faster warm-up while driving gently theory. I'll putz down the street at barely above idle speed, then still go slow in top gear until the temp gauge moves (which happens pretty quickly- FAR quicker than the time most people around here idle via remote start).
If it's -30F I'll let it idle while I'm scraping the windows, and that's about the only idling time my engines ever see.
Old 08-09-2016, 12:51 AM   #15 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
Agree totally. The only reason to idle for warmup is if the vehicle is iced / frosted up and it is unsafe to drive it. If it is really freezing a brief idle (1-2 mins max) helps to get a bit of chill off before loading the engine up.
Simon
Old 10-05-2016, 01:27 PM   #16 (permalink)
Two weels Zero sparkplugs
I've always wondered why electric block heaters aren't more popular in the States, in the Northern part of Europe the are really common.
Old 10-05-2016, 03:43 PM   #17 (permalink)
Ignorance and laziness.
Old 10-08-2016, 04:24 PM   #18 (permalink)
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
In the northern parts of the USA plug-in heating is common. Some stores have plugs in the parking lots so people don't idle wile in the store shopping . Were plugs are scarce like ranches some just don't turn it off till spring ,for if they do they have to tarp the truck start a fire under the oil pan and hope it starts.
Northern US is like northern EU . Southwest US is like the Middle East temperature wise. I've had my temp gage read 117°f before starting cold in summer in Vegas . Was in Las Vegas last week @102°f now home grass is frosty by 7:30pm. And first dusting of snow@5500'. Also most people under 35 have never experienced a cold-blooded carburetor were fuel wash down was a major problem. So for most idling till it is drivable is unnessasary.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
Old 10-13-2016, 03:32 AM   #19 (permalink)
With a carburetor, it was essential to let the car idle for minutes before driving it in order to make sure the engine would run properly. But with modern cars, it's not the engine itself that needs to be warmed up when it's cold outside. Experts are torn on this issue.
Old 10-13-2016, 09:49 AM   #20 (permalink)
All my cars still have carbs but the effect is most noticeable on my XJ600 which suffers from carb icing when you go on the motorway before warming up.
