Old 07-12-2021, 11:46 AM   #21 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Air conditioning usually can work on heating too, so it's not useless even in cold weather.
True. Scanguage shows the Prius uses the AC for heat depending on which vents you have on. Even when the defrost and AC buttons are not pushed. Defrost is why i mentioned he might wanna fix it. Foggy windows suck ass to drive with.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 07-13-2021, 08:00 PM   #22 (permalink)
Even at home, sometimes a foggy window becomes a PITA.
Old 07-13-2021, 11:34 PM   #23 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
Funny that this came up. I was about to ask a technical question about my AC.
I think if I grenaded the compressor, I’d pull it all out and enjoy the weight savings. That’s expensive and requires some fairly professional attention which I’m not willing to pay for (nor able...I blame my watch habit.) Otherwise...if it’s basically working and just needs a fairly minor repair, yeah, I’d try to save it.
I quit trucking and have a couple of jobs right now. One is basically out in the elements out in humid subtropical Texas. Highs this week should be around 95*f (35*c), generally with high humidity, so this is the first time in my life where I genuinely want the small luxury of air conditioning in my car.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 07-14-2021, 11:58 AM   #24 (permalink)
Dark Egg - '12 VW Touraeg
Not sure if I would be OK with propane leaking under the hood.
I actually had a major leak (that I caused trying to find a small leak) on my home A/C filled with propane that I braze weld shut while it was leaking. Yes it made a mini torch out of the leak area and I wouldn't want to try that again but it wasn't as catastrophic as you would think. Actually had it been filled with freon still, that event would have made much more deadly phosgene gas in my basement.
Old 07-14-2021, 07:18 PM   #25 (permalink)
Either way or another, I'd rather drain the gas before working on the plumbing of an air conditoner. On a sidenote, was it out of question to patch the leaking area with Araldite or something similar?
