Old 11-25-2017, 06:00 PM   #1 (permalink)
90 day: 29.44 mpg (US)
Wouldn't erosion cause sea levels to rise?
Can anyone access this:
Another Important Factor of Rising Sea Level: Soil Erosion - Zhang - 2012 - CLEAN – Soil, Air, Water - Wiley Online Library ?
I searched Google for "how much does erosion increase sea levels?" and that was the only article that I found that did not claim that George W-made global warming was causing the sea level to rise, which was causing erosion.
I am not saying it is not, but isn't there natural erosion? Rainfall and waves on beaches? I was putting my full energy into studying for the GRE and I remembered that Chris Isaak went to reshoot some footage for "Wicked Game," but the beach had eroded.
Apparent confirmation (but nothing worth quoting): https://www.e-education.psu.edu/earth107/node/886
Oh right. I need to study!
Old 11-25-2017, 10:22 PM   #2 (permalink)
Or a 8 magnitude earth quake that cases the sea floor to raise nearly 100ft.
Since the earth's gravity and force or rotation will actually cause the sea level to rise faster in the middle of the Pacific more than anything.
Depending on how the added water acts it may cause sea levels to briefly decline.
Old 11-26-2017, 03:22 AM   #3 (permalink)
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
The increase in the sea level is what causes the extra erosion.
The Following User Says Thank You to Natalya For This Useful Post:
freebeard (11-26-2017)
Old 11-26-2017, 04:07 AM   #4 (permalink)
You are not paying attention. Did you read the article? Okay, here is another source: https://www.nationalgeographic.com/e...ea-level-rise/
It says that you personally have caused the sea level to rise several inches in the past century. So what? What difference does that make? You still have rain and waves causing erosion. So, maybe it is eroding sand and soil a bit higher.
This does not change the fact that rain and waves cause erosion and erosion causes the sea level to rise. I shared a source supporting my argument. Are you going to find one saying there is not any natural erosion?
Old 11-26-2017, 01:15 PM   #5 (permalink)
Nope, I'm saying that natural erosion is balanced (over the long term) by natural uplift. As for instance I live on the edge of a substantial mountain range (Sierra Nevada) that wasn't here about 40 million years ago, and which is growing at 1-2 mm per year: https://www.unr.edu/nevada-today/new...-nevada-uplift I've hiked around the Alps, which are mostly limestone formed at the bottom of the sea. Likewise the white cliffs of Dover. And see Darwin (and many subsequent authors) about the way the Andes are being uplifted...
Old 11-26-2017, 03:30 PM   #6 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
If they're getting taller, are they also getting wider? Does that reduce the amount of ocean space nd therefore cause the oceans to rise?
Old 11-29-2017, 03:47 AM   #7 (permalink)
Yeah... as land erodes, it gets lighter, and should rise above the general level of the ocean.
This is what's been happening in many northern latitudes, as the land is *still* rebounding due to the retreat of glaciers from the last ice age.
Old 11-29-2017, 04:07 PM   #8 (permalink)
Mountain ranges and land ice have "extra" gravity that has a very large effect on sea level. Antarctica has so much ice, it pushes the land down almost 1/2 mile, and the sea level south of the equator is something like 8,000+ feet higher. The oblate spheroid of our planet (because of it rotating on its axis) is "sagging" southward. Here's an article that explains it:
https://www.npr.org/templates/story/...toryId=9428163
Because water expands as it warms, this spreads it out over a greater area, so the mass on any given spot is slightly less.
Old 11-30-2017, 12:56 PM   #9 (permalink)
...the sea level south of the equator is something like 8,000+ feet higher.
That's just plain wrong. Sea level is defined WRT gravitational equipotential surfaces (plus a small contribution from the centrifugal force of Earth's rotation), NOT distance from the center of the Earth. If the sea level was 8000' higher south of the equator, the water would flow north until the levels equalized.
Old 11-30-2017, 02:27 PM   #10 (permalink)
Not I.
Maybe Natalya is like me.
Your linky-dinky is unresponsive to the question
When sea levels rise rapidly, as they have been doing, even a small increase can have devastating effects on coastal habitats. As seawater reaches farther inland, it can cause destructive erosion, wetland flooding, aquifer and agricultural soil contamination, and lost habitat for fish, birds, and plants.
Correlation does not imply causation.
"We're deeply sorry." -- Pfizer
