Old 08-24-2025, 03:56 AM   #11 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
I could never find an answer I trusted about whether or not the Prius could safely coast in neutral. There is no mechanical disconnect in neutral, so something is always spinning. If I was going to neutral coast in a Prius, I would limit myself to doing it at lower speeds. On the energy screen, you can get the same effect by holding your foot on the gas in just the right spot. When all the arrows go away, you're in "neutral."
I've been able to get around 70 MPG at times in our 2008 Prius, but average was more like 45-50 MPG. 46 MPG was the norm on long highway trips. Now it's averaging under 40 MPG, with a worn-out everything. Still a great car and just towed three kayaks to the lake.
Never did any extensive mods to it. Untested smooth wheel covers and a grill block probably made some difference, but the improvements apparently got lost in the noise.
Ours burns a lot of oil at 275k. I highly recommend changing the oil on time. I've heard good things about Valvoline Restore & Protect, but I haven't tried it myself.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
Cd (08-24-2025)
Old 08-24-2025, 01:58 PM   #12 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
That something is MG2, which is perfectly happy freewheeling. I've dropped into Neutral many, many times at speeds >70 mph for coast down tests. The transmission is computer controlled with user requests via joystick, so if it isn't able to do something it just won't do it (like go into Park at freeway speeds, for example).
Aerospace Engineer
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
Cd (08-24-2025), Gasoline Fumes (08-25-2025)
Old 08-24-2025, 04:06 PM   #13 (permalink)
Cd
Ultimate Fail
Cd's Avatar
So the Prius is pretty much just a city commuter car, and not an MPG chamion on the highway even if aeromodded and hypermiled ?
Bummer.
However , by using this technique of engine off coasting, it seems like a G2 Prius could really take advantage of extreme aeromods, since the engine RPM limitation would not be there.
I can't wait to see what results I get.
@GasolineFumes : 70 mpg in a G2 ??
At what speed ?
My main car is so old ( 1993 ) that I looked at the year of your car and thought it was a 4th gen car.
Then I remembered that mine is the same year ! LOL.
@ Vman : Good to see you here. Thanks for your advice !
What is the best instant / short trip MPG reading you have seen so far with your G3 ( with fair conditions such as a flat lever road, and no wind, but taking advantage of that EOC feature and aeromods ?
Old 08-24-2025, 05:30 PM   #14 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I'm not highly educated on the older Toyota drivetrain behavior, but this went away in the newer ones. I suspect the reason for high RPM was not actually battery charge, but a gearing / electric motor RPM limitation. The final gearing is a ratio of gasoline engine and electric motors spinning together or in opposition. The Gen2's were able to get up to around 41-42mph on the electric motor only before maxing out in RPM. Gen3 raised that (I believe) to 46, Gen4 could drop into EV-only in the 70's even though it preferred not to, so there was clearly a mechanical change there.
It's worth noting that Atkinson cycle engines move their peak thermal efficiency point to a higher RPM and lower load point in their maps, though it is still ultimately a limitation due to the parasitic losses of just spinning the engine faster.
This was an A.I. response : Good question — that person’s explanation is actually pretty close to what’s going on.
On the 2008 Prius (Gen 2), the limitations on MPG improvement from aero mods aren’t just drag reduction — they’re tied to how Toyota’s Hybrid Synergy Drive (HSD) is designed. The key factors are:
1. Planetary Gearset / Motor RPM limits
The Gen 2 has MG1 (the smaller motor-generator) acting as both starter and a “virtual CVT” control.
MG1’s RPM is mechanically linked to both the gasoline engine and the wheels.
If the gas engine is completely stopped at higher speeds, MG1 would overspeed (spin too fast).
To prevent this, the ECU forces the ICE (engine) to spin above ~42 mph, even if it’s not providing power, just to keep MG1 within safe RPM.
�� This is the “gearing limitation” your friend mentioned.
Gen 2 → ~42 mph EV max.
Gen 3 → ~46 mph EV max.
Gen 4 → ~70+ mph EV possible because Toyota added another planetary gearset and clutch system that allows MG1 to decouple and avoid overspeed.
2. Atkinson-cycle efficiency sweet spot
The Prius’ Atkinson-cycle 1NZ-FXE engine has its best thermal efficiency at mid-load, moderate RPM (~2000–2400).
If your aero mods reduce load too much at highway speed, the ECU may choose a less efficient operating point (e.g. engine idling + higher MG use).
So unlike a conventional car where less drag = always better mpg, in a hybrid the controller’s “sweet spot” matters.
3. Battery state of charge (SOC) constraints
The car tries to keep the HV battery around 60% SOC.
If aero mods reduce load and the battery starts overcharging, the ECU will spin up the engine to burn off energy — even when you don’t need it.
That limits your ability to take full advantage of drag reduction unless the control system is reprogrammed (which most people can’t do on Gen 2).
4. Fixed final drive ratio
Unlike a manual or conventional CVT car, you can’t “regear” the Prius easily.
The hybrid transaxle has a fixed ratio; all speed/load balancing is done electronically via the motors + ICE.
This makes Toyota hybrids less flexible in how they take advantage of extremely low drag or rolling resistance.
✅ Bottom line:
On a 2008 Prius, aero mods absolutely help (people have seen 5–15% gains depending on how extreme), but you’ll run into diminishing returns because:
MG1 overspeed forces the ICE on >42 mph.
The engine’s efficiency island may not match the reduced load from aero mods.
SOC management sometimes “wastes” extra efficiency.
That’s why Gen 3 and Gen 4 Prius models show bigger MPG gains from the same aero mods — their drivetrain design is more flexible. " ( ENDQUOTE )
Thanks for your feedback !
So if I understand correctly, " freewheeling " in 'N' wouldn't mean the engine shuts off and lets me coast.
The Following User Says Thank You to Cd For This Useful Post:
Ecky (08-24-2025)
Old 08-24-2025, 06:58 PM   #15 (permalink)
90 day: 89.66 mpg (US)
Not quite sure what the engine does, but it's likely spinning. It may not be burning any fuel though. (e.g. "coasting" with the injectors off)
The Insight drivetrain (one I'm very familiar with) could be described as something akin to a G2 Prius drivetrain which only has MG1. There's no power split. (also the engine can't declutch from "MG1")
In the case of the Insight, "MG1" (IMA) can in fact spin faster than the max RPM it can put power out (6500rpm?), it just isn't able to operate electrically. It goes dormant.
I do however drive the Insight around in full EV mode all the time now. The engine is always spinning, but it behaves as if it's in DFCO. You get the losses and drag of spinning the engine but due to the light weight and small size of the car, it's still just about as efficient as most EVs, even having to drag a non-firing engine around.
Come to think of it, I'd like to quantify the power loss of spinning the engine at various RPM. I have the ability to do this now, as I have a realtime watt readout, and I can hold the engine at a fixed RPM with the electric motor and read the wattage. I'll get back to you about this. I'd expect the Prius engine to have ballpark 33-50% more drag, given it's 1.5x the displacement, with an extra cylinder.
Cd (08-24-2025)
Old 08-24-2025, 08:39 PM   #16 (permalink)
90 day: 42.83 mpg (US)
The plug-in Gen III would fire up the engine above 60 MPH, and the common explanation was that protected the MG from over-speeding. That was a problem when I wanted to coast down a hill faster than 60 MPH, but keep the engine off. The trick of modulating the throttle to effectively be in neutral didn't prevent the engine from coming on.
I would shift to N and allow up to 80 MPH coasting to prevent the engine coming on, and then when the hill was over and speed dropped below 60, I'd shift back into D. I don't recall exactly, but the MG was rated to an RPM that translated to 88 MPH, or somewhere close to the speed of time travel. Kicking the engine on at 60 seems too conservative to me, but 80 was probably a bit risky.
Now I'm curious if the hybrid has a speed threshold at which the engine is always on? As far as I recall, the Gen III hybrid and plug-in utilized the same MG1 and MG2, so their specs would be identical.
Cd (08-24-2025)
Old 08-24-2025, 08:42 PM   #17 (permalink)
Possibly different planet gear sizes or ratios?
Old 08-25-2025, 03:56 AM   #18 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Bummer.
At what speed ?
The 70 MPG trip was at night and overall downhill, probably around 45 MPH. About 65 miles total. On the same/similar route, my 2000 Insight can get 100 MPG, instead of its normal mid 60s.
I've found the Prius a little frustrating to improve MPG with, but it's important to remember that the car is already doing a lot for you. It's about 10 MPG better than the Yaris, which uses the same basic engine. Any good hypermilier can get a Yaris to match the Prius MPG, but the Prius driver didn't have to do anything special.
https://www.fueleconomy.gov/feg/Find...24807&id=24808
Despite what the EPA estimates show, we've always gotten better highway MPG than city MPG in the Prius.
The G2 Prius drives great as an EV. I even installed the EV switch that was available in the rest of the world. But the small battery doesn't give you much range. A bigger battery and plug-in conversion would be a great mod for short trips. FYI: I rarely use the EV switch. The car automatically uses EV mode without the switch anyway. And it's so easy to forget that you're in manually-switched EV mode. You just drain the battery and then the engine burns extra gas to charge it back up!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following 3 Users Say Thank You to Gasoline Fumes For This Useful Post:
Cd (08-26-2025), pgfpro (09-12-2025), redpoint5 (08-26-2025)
Old 08-25-2025, 04:56 AM   #19 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
Reread this thread?
https://ecomodder.com/forum/showthre...ing-32497.html
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
Cd (08-26-2025)
Old 08-26-2025, 09:41 PM   #20 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Wow.
WOW !
I forgot all about that one !
It's been a decade now guys.
I read the entire thread three times over.
Am I the only one that is not seeing the link to that drone video ???
I would love to see that !
Also, I see mention of low 60s MPG, as well as a trip that had 73.5 MPG @ 50 MPH speeds ( but not a steady 50 mph )
I'm also not seeing the A-B-A test resulls for the mods, or the results at the 65 MPH runs he planned on doing.
I did see the breakdown of all mods together minus the tail, and then with the tail added in, but just vaguely.
+7.5% @65 mph and +10% for the tail.
Does this mean a combined total of 17.5% @ 65MPH speeds ?
If so, + 17.5 % of which baseline ?
Gasoline Fumes (08-29-2025)
