Old 11-02-2010, 09:31 PM   #1 (permalink)
Best battery
What's the best available battery today for an electric vehicle, in the 5K cost range?
regards
Mech
Old 11-03-2010, 04:10 AM   #2 (permalink)
jackbauer's Avatar
In my opinion it would be headway lithium cells. I'm putting together a 9kwh 144v pack for well under 4k usd.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 11-03-2010, 10:07 AM   #3 (permalink)
Juiced Drag Racing
Juiced's Avatar
1929 Model A on E85 - '29 Ford Model A Street Rod
I ditto the Headways. I have them in several converted Motorcycles.
The biggest thing is to get them "happy". Work them in like you would a ICE motor. 50+ plus charges/discharges with light loads. Then...have fun!!!
Here I am having some fun with the Headways....
juiceddragracing.com
Old 11-03-2010, 12:54 PM   #4 (permalink)
...beats walking...
...I'd like to SEE a side-by-side comparison chart or table showing the PROS & CONS of all the currently usable batteries, ie: lead-acid, deep-cycle, Lithium, Nickel-hydride, etc.
Old 11-03-2010, 01:45 PM   #5 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Then we should start adding it to the wiki
EV Batteries - EcoModder
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 11-03-2010, 08:36 PM   #6 (permalink)
24.27 lbs per gallon Co2
Oval_Overload's Avatar
Unicorn - '12 Nissan Versa 1.8S hatch
90 day: 31.9 mpg (US)
This is just the thread I was looking for
Does anyone have an opinion on the US Battery 6 volt floodies? A pack of those would cost 25% less than Trojan floodies for the Jet Electrica 007 I'm buying.
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
Old 11-03-2010, 09:23 PM   #7 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Trojans are unfortunately going down the smithouse due to a change in management.
US batteries at the moment are better, and its too bad
Old 11-03-2010, 11:22 PM   #8 (permalink)
dday's Avatar
Any one use Thundersky or have experience with them?
Old 11-04-2010, 10:11 AM   #9 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
With the Headways how do you manage the batteries and charge them?
I was looking at the Engener batteries that are sold for plug in hybrids because they come with everything.
The Email they sent me included this information:
standard pack is 24V 80AH. You can use two packs in series and two strings in
parallel. Two BMS to monitor two strings. The normal discharge rate is 160A-320A in this
configuration. each 24V80AH pack is $800, BMS is $170, 15A charger is $150. The total for
this 80KWH pack would be 4 x 800 + 2 x 170 + 150 + $250SH = $3940
Old 11-06-2010, 02:22 PM   #10 (permalink)
that seems like a nice deal
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 265 06-18-2020 02:15 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 49 07-06-2014 10:27 PM
Battery options for EOC - long distance brucepick EcoModding Central 19 09-04-2010 09:38 AM
Q: Do discharged lithium ion batteries have similar "sulfation" prob as lead acid? MetroMPG Fossil Fuel Free 4 12-01-2009 01:06 PM
Correct battery voltage ? groar Off-Topic Tech 2 09-23-2008 09:13 PM
