Acetone?
I saw some stuff on youtube about using acetone. Has anyone done this with success or disaster?
Thanks in advance KCF3712 |
Do a search here on EM -- it is bunk.
negible difference when ran in my rolla...
most I got was a cleaned combustion chamber, from the slower more complete burn, which did improved mileage... but then I stopped buying acetone and my mpg stayed up, so it wasn't the acetone, it's the slow long cleanse I gave the engine. so yea, busted |
...also, acetone is an excellent "solvent" of gasket materials.
...moreover, it 'eats' rubber and neoprene gaskets used in conventional carburetors--I know first hand! |
You won't find (to my knowledge) any scientific test showing a significant effect.
As mentioned, do a search - lots of prior discussions. |
and also, I just did 2oz per tank full since I read somewhere all you really needed was that, since if you used anything more than 4oz your MPGs would go down anyways.
found a link... Directory:Acetone:Honda:Del Sol:Robert - PESWiki take it with a grain of salt |
